Star Performance
Go Back   SEAT Cupra.net - SEAT Forum » Diagnostics, Tuning and Modification » Engine Tuning » TDi Tuning
TDi Tuning Hybrid Turbo's, Chips, Software for Diesels. All models covered
Reply
Thread Tools Rate Thread Display Modes
Old 04-11-2008, 01:06   #1
hakanturhan
300hp tdi
Hi..
Which turbo?
Which clutch set?
Which exhaust system?
Which software?
Which injectors?
Which other things are needed for a 300hp or more hp Ibıza Cupra TDI???
hakanturhan is offline   Reply With Quote
Old 04-11-2008, 01:15   #2
hakanturhan
300hp tdi
Hi..
Which turbo?
Which clutch set?
Which software?
Which injectors?
Old 04-11-2008, 09:16   #3
ross p
R14 SSP
ross p's Avatar
use the search
ross p is offline   Reply With Quote
Old 04-11-2008, 10:27   #4
T. Spark
Banned
T. Spark's Avatar
Quote:
Originally Posted by ross p View Post
use the search
Well thats helpful when NO-ONE has ever got 300hp from a Cupra TDi before
You will need a big turbo I got told the hybrid V6 tdi is good for 300bhp, with that amount of power IMHO the only clutch I would look at is a Helix clutch rated to well over 400lb.ft. Exhaust, a full de-cat 3'0inch system should do once you have the custom needed manifold for either end. Software, take your pick, thats down to who you prefer, im sure a few good mappers in the UK could do it? Jabba? RS? P-Torque? As far as injectors go, id say you will need to upgrade, to which ones I dont know. Alot of people upgrade to say get 250hp however ive been told that the standard ones are good for this, anything after will need them. As far as what else is needed, id imagine it being very laggy even with 300hp so a NOS system for anti-lag perhaps to make it truely fast? Then obv you will need a L.S.D + everything handling mod available, no point having that power and not putting it down on the tarmac now is there. Ohh and W.I with a hint of methnol to keep temps down id imagine would be a good thing.
You will need alot of money
T. Spark is offline   Reply With Quote
Old 04-11-2008, 10:56   #5
devonutopia
fabia-lous
devonutopia's Avatar
Quote:
This is the most important mod! Go rob a bank.
__________________
Jason. Drives PD260 Skoda Fabia, yummy
http://www.youtube.com/watch?v=9BvjJjL7Z50
PD260 dyno run video.
devonutopia is offline   Reply With Quote
Old 04-11-2008, 10:58   #6
T. Spark
Banned
T. Spark's Avatar
Quote:
The only mod I am yet to do... I like my bum hole as a one way street
Old 04-11-2008, 13:08   #7
hakanturhan
T. Spark
use the search
Thank you for the answer T. Spark...
@devonutopia
How could you get 260??? Is there a way to reach 300hps with a similar setup with you??
Which parts are the best for highest hp??
Old 04-11-2008, 13:55   #8
T. Spark
Banned
T. Spark's Avatar
I am set to run 260hp (max of my TD2 turbo) as soon as I clean out my inlet mani, egr and pipes, add W.I and then turn the map up a tad
I believe he has a VT5, which should just about be good for 300hp?
Have you got a cupra tdi already? what mods do you have?
230bhp is easy enough to get to, then add a few other bits to get closer to 260hp however at that you will need alot more work done.
Devon - Do you have a new racing cam?
Old 04-11-2008, 14:10   #9
hakanturhan
Yes I have a 05 Cupra TDI...
modifications are:
Gt 2052 compressor from a volvo d5 and stock 17vb manifold and turbine
Turbo-back exhaust
Green Panel Filter
Custom remap
With this setup I already have problems like clutch slip, ECL at 200 210km/h, and boost issues (positive or negative deviatoion @ higher or lower ends)...
I am running around 30psi and currently Cupra is faster than a 230 hp Civic Type-R
http://videos.streetfire.net/video/C...Ctr_182313.htm
http://videos.streetfire.net/video/E...pra_188786.htm
http://videos.streetfire.net/video/A...upe_189062.htm
CLOSED TO TRAFFIC
Old 04-11-2008, 15:41   #10
T. Spark
Banned
T. Spark's Avatar
Hmm normally a negative/positive problem is due to the VNT sticking? What power do you have already? Are you running a standard clutch I assume?
Upgrade the clutch then look at a water/methnol mix to lower inlet temps, people have reported a 15hp increase just in lowering temps nevermind then mapping around them.
Old 04-11-2008, 15:46   #11
hakanturhan
Clutch is standart and it is slipping if I see like 20psi or more at 2000-3500rpm range...
Which turbocharger and manifold should I use???? Can u give me a link with prices written??
And you said water/methanol mix.. Will it be like spraying on the intercooler???
Old 04-11-2008, 17:43   #12
T. Spark
Banned
T. Spark's Avatar
I cant give you a link to the turbo or manifold im afriad as I dont myself. However Turbo Dynamics do the V6 hybrid but you will need to then source a custom manifold as the V6 obv. wont fit otherwise.
W.I spray would be fitted to the Seat Sport intercooler and sprays 'inside' the intercooler not on it as such.
How much torque are you running then out of interest? lb.ft or Nm?
Old 04-11-2008, 18:35   #13
devonmikeyboy
Senior Member
devonmikeyboy's Avatar
Quote:
Originally Posted by hakanturhan View Post
Hi..
Which turbo?
Which clutch set?
Which software?
Which injectors?
Just my opinion for a road car:
Turbo
A GT2556V will produce 280-290bhp with some NOS 300bhp+ could be made.
A hybrid GT3067V will make 300bhp+.
Clutch
Spec 3+ or a South Bend clutch.
Exhaust.
Anything you like as long as it is free flowing and bigger the better within reason.
Software.
You can have the best software in the world but if the mapper doesn`t know how to use it or map diesel cars it doesn`t mean diddle.
Injectors.
R783 injectors will reach 260-280 bhp. There are larger injectors on the market but not suitable for road use. Extra fueling usually comes from water/methanol or propane.
Theres lots of ways to reach 300+ bhp but it comes down to funds, what the car is wanted/needed for, your personal likes/dislikes etc.
__________________
06 Audi 2.0 PD140 Quattro 330 bhp @ flywheels 263 bhp @ wheel 490 lb torque. .Magazine write up here. Now rebuilt Cryo engine/gearbox,bigger turbo+injectors,water/methanol etc.PD140 engines,injectors,heads sale. 2nd car 500bhp MK4 Golf R32 turbo.
devonmikeyboy is offline   Reply With Quote
Old 04-11-2008, 19:06   #14
devonutopia
fabia-lous
I am on the lookout for a good, reliable cam. I've been bitten once by a dodgy cam and I don't intend to repeat that. I have a new map on the way which I hope will see me higher. Boost is being upped to 2.2 bar and hopefully cleaned up a bit too. Just struggling with the uploading.
260 is achieved mainly thanks to the nitrous and water/meth, but as neither have been mapped for the car feels just as fast with it turned off and is does with it on.
__________________
Old 04-11-2008, 19:10   #15
devonmikeyboy
Senior Member
Personally i would be very reluctant to have a high lift cam on a 8v petrol road car so i wouldn`t touch one on a low reving diesel road car.
__________________
Old 06-11-2008, 14:36   #16
hakanturhan
Quote:
Turbo
Clutch
Exhaust.
Software.
Injectors.
So if we decide on gt2556, which manifold will we use???
We are talking about 280-300 hps so will the stoch head need some changes like bigger ports or valves??
and cams?? stock cams with 300hp???
Old 06-11-2008, 15:03   #17
T. Spark
Banned
T. Spark's Avatar
Cams are a weird subject, ive heard a few say they will do good for more power, others say its not worth the hassle.
Old 06-11-2008, 15:32   #18
hakanturhan
Its a diesel car, and daily driven....
what kind of hassles? Have you heard about them?
Old 06-11-2008, 18:47   #19
devonmikeyboy
Senior Member
You can modify the original log manifold that came with the GT2556 so it fits your engine or get a custom tubilar manifold made. You will not "need" bigger valves or port the head but it all helps then again how much money are you willing to throw at the project as you can get forged pistons and rods but do you really "need" them ? Stay with the stock cam for road use. Unless it`s a race/drag car where you will never be below 3000rpm a cam on a low reving diesel car is a bad idea as you will gain some power at the top but loose power low down making for an even shorter useable rev range to drive with.
__________________
Old 21-11-2008, 05:53   #20
hakanturhan
You can modify the original log manifold that came with the GT2556 so it fits your engine or get a custom tubilar manifold made..
If I install gt2556, what will happen to VNT system????? does that turbocharger has a VNT system??
Is it possible to modifiy original manifold(gt17vb manifold) to fit gt2556???
And when will the Cupra start boosting with gt 2556????
Reply
Bookmarks
« Previous Thread | Next Thread »
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
(View-All Members who have read this thread : 236
140SPORT, A-P, A.m.C_Ibiza1, air121005, alex88, alexj124, alextz, allen1020_0, alx_chung, andypandypoos, AP2000, atothej86, AVIHAI-TOPOR, b9rgo1234, badbill_uk, bai_ILIA, bbewekim, ben@MAS, bertrum, Bignod00, billy_cupramk2, BKR, Black TDI Turbo, bobby singh, bobstar, boogiewa, BoraCANLI, brad1, Breezapom, bsc8180, caffeineaddict, caney, CatB1, cav, Celcius, chapelhill, chispadete, chris toone, chris1985, ChrisGTL, CJRamze, cocadave, cooper22, correcaminos, CrossyR, Cupra Kev, cupra.steve, cupra67, CupraOl, cupratdi-matt, cupra_clive, cupra_matt, D3DNA, dan (s1 pru), dannyFR+tdi, danwfr, darkhorse, dave fr, dave mac, davescupratdi, Dave_88, davidif, davie, Deanf, deanomite, delaxm, deliss, devonfr150, devonmikeyboy, devonutopia, dholdi, DIFT, diss_50, DjAlcohol, dontbeefkeith, drifter, Edgeman, egypt, erichuyn, erminio, evoke1xt, evolis, faboka vrs, fenwick458, fordie2, FR-Pete, frantz, FSiLeonMike, gavinchappell, gazp123, George K, georgebibizafr, Gibon, gingerben, glynnd, googies, gp200sx, GrahamFR, grq, gti gadge, hakanturhan, holty, Husbandofstinky, ian_cupra, ibizadoyle, ibiza_1.4tdi, ibzfr, jabba_luke, Jace, jasengine, jaymd, jay_jay, jenk, jj cupra, jobu, Johnnymorris, john_tdi, jonathanp, Jonezyfr, jonjay, jonno_uk, jpcibiza90, K3mist, KarlMac, kaye, KingAnt, koerr, KOMAP, konengs, ktulumike, lamchops85, LeeC, leero783, leonbtcc140, Leon_MHX, lewis, Lukin, m0rk, M1KEH, madmonk, malky39, map man, markgre, markmck, mas430, mat20vt, Mattb82, mattcogg1981, MattFrench, mattytmc, me&mycupra, micky 32, mihaib, MJ89, muddyboots, NickyJam, nikstar, noktoto, number2, oilburninnut, Oily, olaf, orange, P-torque.co.uk, paul-murphys, paulgriffiths0, paulmc, pete34a, Phil MC, phpgear, Pinocchio, pipe, PLuKE, POB, PostieTdi, Poverty, puiutu, push, revo, revo carl, Revo Kev, RichardBW, Richy!!!, ross p, Russ_tdi, ryanp, s20ty c, S3 AKR, sanchez, satan gt, seat110craig, shaun 'e' Fish, Shrek1802, sidennis28, silver surfer, Sisson, skullmunki, slick, slimjim, sooty22, SP33DY, Space Coyote, stewbie55, STOCKY, Street, string, stuartsjg, Swordjo, sxi20vt, T. Spark, Tam_171190, Tartan58, TazB, TDIPower140, Tdi_sport_JT, Tom., TommyG, toughy, traumapat, TriggFr, tsh, turkish, UKLooney, UncleFester, vekic, Wassy, willbr8132, wjohnson, wuciwug, WW_VRS, y4n, Yello, YIN, zacg90, zilcho, __B3NNY__
Thread Tools
Display Modes Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
turbo lag? or my imagination? remapped TDI david burton TDi Tuning 14 04-03-2008 14:17
Re: [AutoBild Sportscars] A3 TDi vs. 120d, Mégane, Leon FR & Golf GT TDi Poverty Leon Mk2 1 02-03-2008 01:13
Fr tdi clutch same as Cupra tdi? Nick_J Ibiza Mk4 21 15-01-2008 10:44
Arosa TDI Cupra_joeboy Arosa 10 17-12-2007 08:16
TDI vs FSI Buck_geraint Leon Mk2 9 29-10-2007 14:38
Website © 2010 SEATCupra.net
Disclaimer: SEATCupra.net is not an official SEAT site and is not affiliated to SEAT in any way. Visit the Official SEAT Website.
SEATCupra.net are not directly responsible for information which maybe posted in this forum.
All content is viewed and used at your own risk. We do not warrant the accuracy or reliability of any of the information.
The views expressed herein are those of the individual contributors and not necessarily those of SEATCupra.net or SEAT
All trademarks and copyrights remain property of their respective owners.
