AMD Technik
Go Back   SEAT Cupra.net - SEAT Forum » Diagnostics, Tuning and Modification » Engine Discussion » TDi - SEAT Diesel specific topics
TDi - SEAT Diesel specific topics exclusively for SEAT diesel specific topics only.
Reply
Thread Tools Rate Thread Display Modes
Old 24-11-2009, 19:45   #1
cypher007
cypher007's Avatar
cypher007 has 10 points
morning start problems and air bubbles in the fuel line
weve got an 03 Seat Toledo which has a constant stream of air bubbles running along the transparent fuel line. once the car is started it doesnt seem to affect performance, but heres the wierd thing:
start after 8hr day at work OK.
start in the morning, hmm, needs at least 2-3 goes, it just catches then stops, before it finally starts.
ive bought a new fuel filter, £24 HOW MUCH!!!, and the plastic T piece £20 HOW MUCH!!!. so before i fit the T piece id like to know if it is probably going to be an air leak here, or if i should be looking elesewhere. the VW stealer said it could be the electric lift pump, cant see this myself as how does that equait to getting air in the fuel system.
one other note, the garage that used to service it said the reason they fitted a new fuel filter and two cans of fuel cleaner was becuase:
the previous owner tried some bio-diesel, hmm.
__________________
SEAT Toledo SE 110bhp 03 plate for work and shopping
VOLVO 850 T5R yellow 1 of 69 made, about 280bhpfor scaring myself when needed
cypher007 is offline   Reply With Quote
Old 24-11-2009, 19:55   #2
MJ
Cha'mone
MJ's Avatar
MJ has 40 points
Possibly glow plugs or injector seals, a little air in the fuel lines can be normal.
__________________
Follow us on Facebook - Prosport Stockport Call us on: 0161 432 9999 Email us: pro-sport-ltd@hotmail.co.uk
MJ is offline   Reply With Quote
Old 24-11-2009, 20:10   #3
cypher007
cypher007's Avatar
Quote:
i have replaced the glow plugs, only to find out they dont actually come on until about 5c. the injector seals, hmm, would this mean fuel is slowly seeping into the cylinders? as it is quite smoky when it does catch, but it soon clears.
the bubbles are maybe 10-30mm long depending on if its running or not.
__________________
Old 24-11-2009, 20:57   #4
yorkie1
yorkie1 has 10 points
air in the fuel would be a problem for starting must be sucking air from somewhere or fuel could be leaking back to tank could try a non return valve?
yorkie1 is offline   Reply With Quote
Old 24-11-2009, 21:46   #5
Muttley
Catch that diesel!
Muttley's Avatar
Muttley has far too many pointsMuttley has far too many pointsMuttley has far too many points
The TDI 110 engine isn't PD and doesn't have a lift pump.
The T-piece, if it is the one that fits in the fuel return line on top of the filter, is a thermostatic valve that lets hot fuel into the filter to speed up the thawing out of the fuel going to the engine on cold mornings. So it isn't just a bit of pipe :-)
Muttley is offline   Reply With Quote
Old 25-11-2009, 09:36   #6
Andrewcupra TDI
Resident Desk Jockey
Andrewcupra TDI's Avatar
Andrewcupra TDI has 20 points
this seems to be my problem too , only i cant see bubbles
but mine doesnt want to restart when hot,
i do get a cloud of white ish smoke on first start
__________________
Flash Red Cupra TDI OEM +
Changing all the things that should have been as standard
198.7bhp & 293.0 lbft on tesco's cheap $hit 6/12/09
Andrewcupra TDI is offline   Reply With Quote
Old 25-11-2009, 15:28   #7
cypher007
cypher007's Avatar
ahh cheers Muttley. the reason i was going to replace it was because it has an O ring and i wondered if air could be being sucked in around the O ring, and then fed to the main fuel line to the pump via the top of the filter?
__________________
Old 25-11-2009, 17:28   #8
JR_130
JR_130's Avatar
JR_130 has 10 points
My Dad had this until recently when he got the fuel temperature sensor replaced on his Octavia, way easier to start when hot now.
JR_130 is offline   Reply With Quote
Old 25-11-2009, 18:47   #9
MJ
Cha'mone
MJ's Avatar
MJ has 40 points
Quote:
I think andrew's tried everything under the sun to resolve his issue mate, including his fuel temp sensor.
__________________
Old 26-11-2009, 13:10   #10
Andrewcupra TDI
yep you rite there, has been suggested crank sensor or camshaft sensor ,
__________________
Old 28-11-2009, 13:46   #11
cypher007
cypher007's Avatar
it was really bad this morning
this morning it was really hard to start, and yet the glow plug light came on for a little longer than usual, as the outside temperature was 4.5. so im guessing even with glow plugs running its still got big problems somewhere.
could i have a blocked/restricted intake? i set the EGR to 33768 to close it using vagcom, but the car had already covered 65k when i bought it.
i wondered about using some of those 10k foam treatments through the intake.
__________________
Old 29-11-2009, 10:40   #12
rallynut
rallynut has 10 points
just a bit of info for you all,
my work van a mitsibushi l200 had the same problem as all of you are mentioning along with lack of power poor starting both cold and warm but worse when warm and after changing loads of parts it was a faulty relay that the glow plugs use thats about all the info the garage gave me at the time i picked it up as i spoke to the receptionist,
maybe of use to you.
rallynut is offline   Reply With Quote
Old 29-11-2009, 18:52   #13
cypher007
cypher007's Avatar
hmm
tomorrow morning i might, if ive got time, check the supply to the glow plugs, as it should be cold enough to bring them on. is there any way of increasing the temperature at which the glow plugs are turned on? maybe taking it up to 15c.
__________________
Old 04-12-2009, 11:01   #14
cypher007
cypher007's Avatar
ok an update
weve replaced the fuel filter and the T piece. it still got bubbles in the fuel line . so now weve tried feeding the filter from another piece of pipe and still bubbles. so the air is getting in on the return side somewhere. any ideas?
__________________
Old 04-12-2009, 17:03   #15
brad1
Banned
brad1 has 10 points
Mine has bubbles, not loads, but you do get bubbles in the fuel line, and mine starts up rough on cold mornings, doesnt struggle to start, but splutters once, i think maybe a on the way out glow plug relay
brad1 is offline   Reply With Quote
Old 05-12-2009, 00:12   #16
JamesL
Senior Member
JamesL's Avatar
JamesL has 40 points
mine has bubbles. Got one when my cambelt was done and then a few more when I changed the fuel filter
__________________
Alfa Romeo Giulietta - 2.0 JDTM Lusso
Was - Seat Leon Cupra 1.9 tdi
JamesL is offline   Reply With Quote
Old 07-12-2009, 09:44   #17
cypher007
cypher007's Avatar
update
right the guys here in motor vehicle have found, that with the T piece removed from the filter, the T piece socket blanked off, and feeding the filter direct from a bucket of diesel, weve still got bubbles. so the air must be getting in around the edge of the filter or the drain off.
anyway i took the new filter back to the VW dealer and they wouldnt change it . they said i would have to buy a new one and then wait for a refund from VW if they found a fault with the filter. this sucks and im sure is against trading standards. how do i sort them out?
at the moment ive got the old filter refitted with the new T piece, and ive still got a few air bubbles .
__________________
Old 07-12-2009, 11:01   #18
cypher007
cypher007's Avatar
ok
just read a post on another forum, which basically said that the IP is stong enough to pull air past the hose clips. so i think ill go and get some of those fuel line clips that have like an overlap so they dont oval the pipe, and see if that cures it.
__________________
Old 07-12-2009, 18:43   #19
ralph
ralph has 10 points
before you do that try smearing a bit of vaseline round the hose connections on the fuel filter.
Mine has air bubbles in the fuel line and it does not like a cold start but it does not sound like its as bad as yours, Mine fires up pretty quick and just chugs for a few seconds.....only when the temps are pretty close to 2degC or lower. It was still starting like that at minus 6 last year though so I will just live with it
__________________
52 Leon 110 TDIse in silver
05 Fabia VRS in black
ralph is offline   Reply With Quote
Old 27-01-2010, 11:21   #20
cypher007
cypher007's Avatar
update
right ive found if i turn the ignition on and off twice on the third turn it will start and run. so i think i need to extend the glow time in the ecu, and the temp the glow plugs come on at. is there a way of doing this with vagcom?
__________________
Reply
Bookmarks
« Previous Thread | Next Thread »
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
(View-All Members who have read this thread : 144
adam kelly, adski91, Alhambratdi110, alib44, alien1974, Andrewcupra TDI, ant49, AoS, Art0ir, ashley600, asthpsw, bai_ILIA, bane_punk, batman3000, Beaconjon, bigbrutha, bmb779, BoardTracker, bobamira, bonsaiman, brad1, bubbles1, cdrw, Chester, ChoppySenna, chrisboyle999, Chriswaite130, CMR, cupra-rich, cupratdi53, cypher007, Dajmin, danwfr, dave.richmond, Dave_b, depex, downrodeo, fallenhero, Fl@pper, Fozly, Fraz, FRdan, gac, george130, georgebibizafr, gr066y, GTV, gunsdontkillppl, Hank, higgsy regulato, Hobbiniho, Holmsy, ijmok, JamesL, jamie512, Jayt, jfinn, jonjay, jpskidmore, JR_130, jscottuk, juhema, kyleh060, L17KKE, landie9, leeo, leonrob, Lewis225, Lordhuberti, M1KEH, Mancseat, MarkWales, MJ, mjt, muddyboots, Muttley, MWG, NagaBurns, Nath., Naz, Neo, NI3K, nick9one1, Nightscape, nomis900, nvidia, oldman, passinf, paultoledo, pedro-tdi, peteh, Pheo, PhilOfCas, phtumsh, Pistol Pete, pj110, probee, rallynut, ralph, RazzleUltra, Red ibiza, redderv, Rich110, Rick Adamski, Robertotoledo, ross27, rpk, S3 AKR, sahar, sausage31, scot_bck, seatcupra2001, sibiza, skullmunki, slick, Sloth, southyjd, sssstew, stebbi, stevei'D, stroller, StrongbowRanger, sydoggkdy, sye, tdi_will, techie, thomasa, toledotag, tollydan, tony19b, Turbo Joe, twig, unclerichy, VAG Diesels Rul, vagfam1, validwarlord, Viking, waerwolf, weelieboots, willives, xmichaelx, yorkie1, zedzp, zoheb
Thread Tools
Display Modes Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Ibiza 2.0 16v Gti (ABF Engine) Start and Idle problems. mcdreameruk Ibiza Mk2 19 30-12-2008 12:51
Ibiza Starting and Idle problems - Solved! RohnIbiza Ibiza Mk2 3 01-11-2008 07:22
Missing air intake - problems? bobbycfc Altea - includes XL and Freetrack 1 23-06-2008 22:05
Air Con Problems A1y Leon Mk1 1 04-06-2008 16:31
V5 Underpower, miss-fire, higher fuel consumption, MAF (mass air flow) Crayfordp Mk1 & 2 Toledo 3 27-05-2008 22:12
Website © 2013 SEATCupra.net
Disclaimer: SEATCupra.net is not an official SEAT site and is not affiliated to SEAT in any way. Visit the Official SEAT Website.
SEATCupra.net are not directly responsible for information which maybe posted in this forum.
All content is viewed and used at your own risk. We do not warrant the accuracy or reliability of any of the information.
The views expressed herein are those of the individual contributors and not necessarily those of SEATCupra.net or SEAT
All trademarks and copyrights remain property of their respective owners.
