SERE
Go Back   SEAT Cupra.net - SEAT Forum » SEAT Model Specific Discussion Forum includes Members Projects » Ibiza » Ibiza Mk4
Ibiza Mk4 For the 2002 - 2008 model
Reply
Thread Tools Rate Thread Display Modes
Old 09-06-2012, 23:29   #1
Vasily87
Vasily87 has 10 points
Lambda Sensor?
Hi got an mot done on the good ladies car and the emissions are high so was looking at changing the lambda. However i understand there are two on the ibiza, any way of daignosing which to change or is there one that fails more than the other? thanks, also i have vcds lite if it can help me check!
Vasily87 is offline   Reply With Quote
Old 12-06-2012, 21:23   #2
RUM4MO
Senior Member
RUM4MO has 10 points
As you have VCDS - lite, use it to find out if there are any logged faults - though you would have said if there were, which leaves maybe just an inefficient cat, but the car should have warned you about that. Sounds like you will need to dig deep to get VCDS to help you. Maybe start by checking the plugs and air filter just to make sure the car is fit to run cleanly.
Edit, on re-reading your posting, it sounds like the car passed but some of the readings were higher than you expected them to be, if that is so, then replacing the B1 S1 Lambda sensor, as its the control sensor, doing that should prevent any further poisoning of the cat - the B1 S2 Lambda sensor is just a monitor to check that the exhaust output from the cat is okay. Which engine is fitted to that car?
One thing about VCDS or any other scan tool, its a bit like a socket set, if you don't already know how to do the work then it will not be able to help you - though it should do no harm just to read fields - I've always thought that with a good tool like VCDS, there should be someone out there that could compile a very large list of tasks and how to carry them out. The VCDS website has just a few common application guides - but not exhaustive enough, so there is still some work that someone could do there for some extra cash!
RUM4MO is offline   Reply With Quote
Reply
Bookmarks
« Previous Thread | Next Thread »
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
(View-All Members who have read this thread : 26
Asurik, Badishi, Banzaiii, black night01, cactusjack, chrisRibiza, dc98ddc, deanjb, diggerbycroft, Ferryman, hamlyn, Jimmy98, jonnny.g84, K_1, matty_glanza, moffat11, MrNorma, robertj, RUM4MO, russchallis, stezo2k, such, t0mm_the_tank, trolski, Vasily87, xxjay247xx
Thread Tools
Display Modes Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Website © 2013 SEATCupra.net
Disclaimer: SEATCupra.net is not an official SEAT site and is not affiliated to SEAT in any way. Visit the Official SEAT Website.
SEATCupra.net are not directly responsible for information which maybe posted in this forum.
All content is viewed and used at your own risk. We do not warrant the accuracy or reliability of any of the information.
The views expressed herein are those of the individual contributors and not necessarily those of SEATCupra.net or SEAT
All trademarks and copyrights remain property of their respective owners.
