DPM Performance
Go Back   SEAT Cupra.net - SEAT Forum » SEAT Model Specific Discussion Forum includes Members Projects » Leon » Leon Mk1
Leon Mk1 Use this forum for Leon specific topics, for 2000-2005 models only
Reply
Thread Tools Rate Thread Display Modes
Old 17-06-2012, 10:57   #1
Shmoo
Shmoo has 10 points
2001 LC boost problem
hi all. My mates 2001 lc 1.8 t APP has got what I think is a boost issue. when the engine hits 3000 rpm there is a big hick that goes through the whole car. it only lasts for approx half a second then the car goes as normal. sometimes it does a double hick one straight after the other. The fault seems to be intermitant but happens more often than not. the car is remapped but unsure who by as it was already done when purchased. sometimes the dv can be heard hissing when it happens and other times not.
Up to now we have replaced spark plugs, replace n75 valve , n249 bypass, sai bypass, new dump valve, pressure check from turbo outlet to throttle body(ok) and new fuel filter.
we have checked the faults and found bank one prob one no activity and maximum charge pressure surpassed. could it be that it's over boosting causing this big hick? or could it be the lambda sensor causing fault?
we're are at a standstill to we're to look now. the car also has a Jetex filter fitted. the problem was already present before fitting parts and doing bypasses so they don't seem to be the problem. sorry for the long story and and ideas would be greatly appreciated.
thanks jamie
Shmoo is online now   Reply With Quote
Reply
Bookmarks
« Previous Thread | Next Thread »
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
(View-All Members who have read this thread : 18
abs111, barryk, car.crash, Dan1720v, duanedibbs, hyphon12, kent cupra r, kosymodo, Laoshi, Matty1986, micallef, milner575, nally270lb,TQE, Rob Kelz, Shmoo, sjec, staffyspen, traumapat
Thread Tools
Display Modes Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Website © 2013 SEATCupra.net
Disclaimer: SEATCupra.net is not an official SEAT site and is not affiliated to SEAT in any way. Visit the Official SEAT Website.
SEATCupra.net are not directly responsible for information which maybe posted in this forum.
All content is viewed and used at your own risk. We do not warrant the accuracy or reliability of any of the information.
The views expressed herein are those of the individual contributors and not necessarily those of SEATCupra.net or SEAT
All trademarks and copyrights remain property of their respective owners.
