| Integrated Engineering Integrated Engineering: Enthusiasts dedicated to engineering and designing the highest quality connecting rods for SEAT, VW, Audi and Skoda. Check out our site for all your performance needs including the following brands: JE pistons, Supertech vavlve train, SPA manifolds, Cat Cams, Walbro, Siemens Deka, Bosch, Eurodyne Software, ARP, Peloquin and our own SAI blockoff plates for 1.8t and VR6. |
Thread Tools | Rate Thread | Display Modes |
#1 |
Member
INTEGRATED ENGINEERING's 2.0T FSI product and new release thread.
This thread will serve as the IE 2.0T FSI product library that we continuously update with our new releases. This will make it easy for you guys to find what you are looking for and we wont be making new threads for every new product on this vast and continuously growing platform. Also, if anyone has any questions, comments, or suggestions please post them in here. We offer a huge inventory for VW/Audi and other makes including internals, valve train, fueling solutions, hardware, OEM parts, billet accessories, turbos, and much more. Not everything will make it into this thread, so if you dont see what you are looking for check www.intengineering.com or e-mail sales@intengineering.com
![]() 2.0T FSI Valve Train ![]() IE carries everything you need to build your 2.0T FSI head, from mild to rev-out wild with valves, guides, seals, etc... including IE's own product line, Ferrea, and Supertech components the sky is the limit. 2.0T FSI Ferrea Valves ![]() Ferrea is one of the most known names when it comes to valvetrain, trusted by the top racing teams around the world. Formula 1, Nascar, indy, drag racing, and road racing teams all utilize Ferrea in the world's highest performing engines. Ferrea's Super Alloy valves are made from an extremely heat resistant alloy, that is specifically designed for forced induction and nitrous applications. They have become very popular due to the resistance of high exhaust gas temperatures. This alloy has experienced a great deal of success because it was specifically designed for these applications. Ferrea Intake Valve Set: See more here Ferrea Intake Valve Set +1MM Oversized: See more here Ferrea Exhaust Valve Set (Super Alloy): See more here Ferrea Exhaust Valve Set +1MM Oversized (Super Alloy): See more here 2.0T FSI Supertech Intake Valves ![]() This is a full set of 8 Supertech intake valves for your 2.0T FSI. They are standard size all around and feature backcut intake valves with black nitride coating. All 2.0 FSI feature the single groove conversion with matching keepers for maximum valve retention and stability at high rpm. See more here 2.0T FSI Supertech Inconel Exhaust Valves ![]() This is a full set of 8 Supertech exhaust valves for your 2.0T FSI. All 2.0 FSI feature the single groove conversion with matching keepers for maximum valve retention and stability at high rpm. This set comes with ALL inconel superalloy exhaust valves so they are great for turbo usage. See more here 2.0T FSI Integrated Engineering Valve Guides ![]() Integrated Engineering valve Guides are the performance option for replacing factory guides for new valves. In performance head builds, factory guides are prone to excessive wear resulting in premature valve failures. To combat these issues our valve guides are made from a specialized alloy on our in house CNC lathe with ultra high concentricity for exact valve placement and precise dimensions. Using a proprietary bronze alloy results in faster heat dissipation where thermal conductivity is increased by 10% and extends valve life, guide life, and cylinder head component life. For added performance, these valve guides have been designed with an aerodynamic tip designed to cut down on airflow restrictions in the valve port. See more here 2.0T FSI Integrated Engineering Valve Seats ![]() Integrated Engineering valve seats are the performance option for replacing factory seats when doing your cylinder head build. In high revving performance head builds, factory seats are prone to excessive wear resulting in premature valve failures. To combat these issues our valve seats are made from the same specialized alloy as our valve guides on our in house CNC lathe for dimensional accuracy. Using a proprietary bronze alloy results in faster heat dissipation where thermal conductivity is increased by 10% and extends valve life, seat erosion, and cylinder head component life. Exhaust Valve Seats: See more here Intake Valve Seats: See more here Integrated Engineering FSI 2.0T Valve Spring/Retainer Kit ![]() Integrated Engineering is proud to bring you this very high quality valve spring kit for 2.0T FSI engines. This kit features spring rates which are optimized to match your vehicle specifications and provide proper valve control even under high revving applications. Our springs are wound in the USA from the purest spring steel available in the world, then nan-peened for incredible fatigue resistance. The retainers are CNC Machined in-house from aircraft Titanium to exacting tolerances and surface finish requirements. This valve spring/retainer kit is designed by our engineers to bring you the highest quality performance components and tested for reliability. See more here Ferrea FSI 2.0T Valve Spring/Retainer Kit ![]() Ferrea produces among the top quality valvetrain available, and is trusted by the top racing teams around the world. Heavy duty valve springs will prevent valve float at higher rpm while the titanium retainers will help keep the weight down, while providing extra strength. See more here Supertech FSI 2.0T Valve Spring/Retainer Kit ![]() An absolute must for anyone wishing to stretch the powerband of their 2.0T FSI engine out past 7500 rpm or so safely. These take a two pronged approach by increasing the spring rates meanwhile reducing the mass of the retainer, by using titanium. The use of titanium provides an adequate fatigue life to be acceptable for all but the highest mileage street use. These will allow usage up to 8000 rpm although we have used them for occasional use to 8500rpm on hydraulic lifters. More RPM is possible by converting to solid lifter buckets as there is plenty of spring rate here. See more here
__________________
#2 |
Member
2.0T FSI Bottom End
![]() IE offers everything you need to build a strong short block. We built our name on offering you the strongest and top selling connecting rods for VW/Audi applications and continued on that name to bring you anything you might want from our exclusive Tuscan connecting rods, forged pistons, main caps, dowel pin kits, specialty hardware, and much more to ensure you build a bottom end that can handle anything you throw at it. Integrated Engineering 2.0T FSI H Beam Drop-In rods ![]() For use when using stock pistons only. Integrated Engineering is proud to manufacture the highest quality connecting rods available for European applications, at a reasonable price. This is accomplished through careful design, manufacturing, and quality control processes. With hundreds and hundreds of sets of VW and Audi connecting rods in stock, we are your specialist supplier with the inventory and knowledge to make your project a success. See more here What is a drop in rod? Integrated Engineering 2.0T FSI H Beam 144X20 Connecting Rods ![]() For use with aftermarket pistons only. One of the hallmarks of a high quality connecting rod is its strength to weight ratio. Anyone can create an extremely strong rod out of a huge chunk of steel. Creating one with a reasonable weight that works well in today's high rpm european applications, and holds up to a lifetime of torture is another story. In order to create this balance of strength and light weight, an H beam design is utlized. The design is validated and optimized using modern CAD drafting and FEA analysis techniques. These techniques ensure the rod is as light and strong as possible. Click here to see more Integrated Engineering 2.0T FSITuscan I Beam Rods 144X20 ![]() Tuscan connecting rods represent the leading edge of technology for bottom end strength, reliability, and light weight. Our Engineering staff utilize the most modern computer design technology, including dynamic FEA simulations to optimize these rods to a level never before seen at the enthusiast level. IE Tuscan rods for turbocharged applications feature a robust I-Beam design for incredible bending and torsional stiffness. Additionally, an extensive iterative process lead to the unique Egg shape of our rod beams, which lowers stresses as much as 20% compared to less evolved designs. This shape very evenly distributes the high compressive loading from a turbocharged engine onto the connecting rod beam. We then validated this success with over 18 months of field testing, powering numerous 4 cylinder VW / Audi engines with over 1000 bhp! Click here to see more Watch our Tuscan intro videos: Part one Part two Integrated Engineering 2.0T FSI Girdle kit ![]() Under high RPM and power use your block can begin to flex, causing severe main bearing wear or even a broken crank. Reinforcing the block is a necessity for these extreme applications. This girdle kit uses a 3/8” steel plate to bolt on the underside of your block to reinforce it and prevent from flexing under high power use. The girdle plate bolts to all of the main journals, using the supplied extended-length ARP main stud kit. It is then sandwiched between the block and the oil pan to keep the block from flexing. This kit includes all lengthened hardware needed to install the girdle plate. Spacers are included for use with factory main caps. This kit will remove the factory balance shaft/oil pump assembly, and replace it with a chain driven oil pump. Click to see more Click here to see our girdle installation instructions 2.0T FSI Forged Pistons ![]() Integrated Engineering has a huge selection of Forged Pistons including JE, Mahle, and Wiseco available in various compression ratios, strokes, and bore sizes. Whatever piston combination you need, we have a set to meet your budget. Don't see what you need? We can custom order anything! JE Forged Pistons ![]() JE pistons are a great upgrade for someone looking to build a stout, reliable engine. JE's 2618 alloy is stronger then most other pistons made from 4032, and are specifically engineered for extreme applications, and is why we chose to use them in all our race engines. Dish requires no deburring or preparation. JE's will require a set of 144X20 connecting rods without taper. Click here to see our selection of 2.0T FSI JE pistons Mahle Forged Pistons ![]() Mahle pistons provide improvements in strength over OEM pistons without some of the sacrifices sometimes found in other forged pistons. Precision forged from 4032 alloy, a low expenasion rate aluminum. They all feature forged side reliefs, reducing the weight of the overall package. They also use slipper skirt designs, reducing friction and further reducing weight. Mahle PowerPack pistons feature ultra flat ring grooves, which promote excellent ring seal and most importantly reduce the chances of micro-welding during break in. Every set of Mahle PowerPack pistons comes with their exclusive Grafal skirt coating, which is not only anti-friction but also offers impact absorbing qualities, reducing piston noise and decreasing stresses in the piston skirt. Requires 144X20 connecting rod with out taper. Click here to see our selection of 2.0T FSIMahle pistons
__________________
#3 |
Member
2.0T FSI Billet Accesories
![]() In stock and ready to ship, 2.0T FSI billet engine accessories are the perfect addition to your engine bay. For a improved look or options for big power, we have the billet option for you! Many accessories available in raw, IE Red, or black anodized finish. Integrated Engineering 2.0T FSI Billet Valve Cover ![]() These beautifully finished pieces start off as one large piece of 6061 aircraft aluminum, and are precisely machined on an in-house CNC mill. They are a direct replacement for your factory valve cover, and use the OEM gasket. They have a single -10an outlet for a custom breather setup. To ensure that no oil comes out of the breather, these have welded baffles that are guaranteed to not fail. In place of a factory oil cap, these use a billet aluminum cap with an o ring for a tight seal. Whether you are looking for custom look, or an easy way to start off a custom catch can project, these billet 2.0T valve covers are a great addition to your engine bay! See more here Integrated Engineering FSI 2.0T Boost Cap/Tap ![]() Installing a boost gauge or just need a vacuum source? Our FSI/TSI boost taps will make this a breeze. They are offered in black or red anodize and included all necessary hardware. Also included is an OEM retaining clip that eliminates the "kickstand" feature of other designs. These boost taps are perfect for use in applications where the OEM PCV system must remain intact. Boost cap is for use in applications when the OEM PCV system has been removed. It can also be used as a boost source for gauges or engine management systems in cars with the PCV system removed. This system ships with both a boost cap or tap depending on your needs, along with a new o-ring and clip. Available in IE Red or black anodize or raw aluminum finish. Click here to see boost cap Click here to see boost tap Integrated Engineering 2.0T FSI High Pressure Fuel Pump Blockoff Plate ![]() Once you reach the limits of the stock high pressure fuel pump on the 2.0T FSI engine, there is not many options to maintain the high pressure direct injection system. That is the point that you may want to swap over to port injection and remove the direct injection entirely. We have made this blockoff plate to take care of the hole left from removing the HPFP. These are a direct fit, with an O-ring seal to ensure a leak free connection. See more here Integrated Engineering 2.0T FSI Valve Cover Breather Adapter ![]() Integrated Engineering has a solution for the PCV valve that commonly fails on the 2.0T FSI engines. These beautiful billet pieces are a direct replacement for the faulty plastic pieces that cause rough idle, check engine lights, power loss and decreased fuel economy. This will eliminate the factory PCV valve.This adapter comes pre assembled with the required barb to clip the factory block breather hose to. Unlike other pieces available, ours maintains the two breather outlets for proper crankcase ventilation. These can easily be plumbed to a catch can to collect the oil mist that is emitted. Just like many of our other products, these are made in house at IE on our CNC lathe and mill. See more here
__________________
#4 |
Member
2.0T FSI Hardware
![]() Integrated Engineering carries a huge selection of hardware including ARP bolts, oil restrictors, bolts, fittings, specialty fittings, caps, studs, and much more. This category is growing all the time so check www.intengineering.com for a full list of our huge selection. ARP Head Stud Kit ![]() These American made head stud kits for 2.0T FSI engines, are absolutely the highest quality head stud kit you can find. We are genuine ARP Distributors so buying from us guarantees you a valid warantee. This will ensure your head does not lift even under the most extreme boost conditions and is completely reusable, great for race engines. See more here ARP Main Stud Kit ![]() This main stud kit for VW / Audi 2.0T FSI engines, brought to you by ARP out of California is absolutely the highest quality main stud kit you can find. This will ensure that your main bearings and caps stay put even under the most extreme conditions, eliminating potential bearing problems. See more here. ARP Cam Tower Bolt Kit ![]() This ARP cam tower bolt kit for the 2.0T FSI engines includes all of the bolts and washers needed to replace the OEM bolts that secure the FSI cam tray to the cylinder head. By replacing these bolts with stronger ARP units, you can ensure that your cams will stay put even in the most extreme applications. These bolts are made from the ultra strong ARP 8740 alloy, with rolled threads. See more here. ARP Flywheel Bolts ![]() In high rpm, high power engines, fastening the flywheel to the crankshaft becomes increasingly difficult due to the instability of a flexing crankshaft. These special, heavy duty ARP bolts are uprated from factory units, and are much higher quality and strength. They are made from arp 8740 alloy and feature a 190,000 psi tensile strength. This is for ONE bolt, order 6 bolts for Audi/VW FSI 2.0T engines. Must for high HP engines. More info here Integrated Engineering Designed ARP Crank Damper Bolt ![]() The crank damper and timing belt driver gear interface is one of the most sensitive issues with the 2.0T FSI engine in performance applications. This interface does not have a high safety factor from the factory, and when combined with higher RPM, it can often fail. The loss of timing often causes massive destruction. Integrated Engineering has spent significant time working to improve this interface by collaborating with ARP to produce this aerospace grade fastener which allows a higher clamping load on the timing belt pulley to be used. This ensures that the joint will not slip and shear the keyway. In addition, these high quality fasteners are far more consistant then the factory pieces and are completely reusable. More info here Integrated Engineering EKagrip Flywheel Friction Disk ![]() Originally designed for about 100 horsepower, the 6 bolt flywheel interface on the VW / Audi engines struggles when subjected to serious power. Even with ARP Flywheel bolts, this interface can become taxed and allow the flywheel to slip around under high torque. This leads to wear between the surfaces, and shortly thereafter complete failure of the bolts and joint. In order to fight this we had EKagrip make some of their patented nickel and diamond coated friction shims. These shims increase the friction between the two components by up to 300% and greatly increases the load which can be carried. The shims are .008" thick, and do not cause any alignment problems. Highly recommended for any engine making 450+ ft-lb with the 6 bolt VW/Audi flywheel flange. More info here Timing Belt Gear Dowel Pin Kits ![]() One of the major weaknesses of the 2.0T FSI platform is that the timing belt system is under specced for the large load placed on it. This shows up in belts that fail earlier then expected. In order to combat this, IE has sorted out a dowel pin strategy, placing a 7200lb shear strength alloy dowel pin through the joint to hold the load, even when there is not enough friction on the joint. Ordinarily, this would mean a trip to the machine shop with the crankshaft, but our kit allows the crank to be successfully modified even in the car. Kit includes a brand new OEM timing pulley, which has been drilled, reamed, and then chamfered in our CNC Milling center. This ensures that the bore is placed right on the money and square to the end of the crankshaft. also ncluded a pulley, drill bit, reamer, high strength alloy steel dowel pin and 2 page instruction manual. FSI Crank: See more here MK4 TDI Crank For 2.1L Strokers: see more here Autotech Hi-Volume Fuel Pump UpGrade Kit 2.0T FSI ![]() After months of testing and design, Autotech has designed this high volume fuel pump for the 2.0T FSI engines. This kit will take care of the commonly found fuel cut problem with the 2.0T. They use a high grade materials, along with aircraft grade machining to bring you these high quality fuel pumps. They will allow you to use your factory high pressure fuel pump to 300+ horsepower. See more here KMD Tuning High Pressure Fuel Pump Kit for 2.0T FSI ![]() This is a KMD Tuning 2.0T FSI high pressure fuel pump upgrade kit. This kit will allow your pump to deliver 40% more fuel, which is necessary for stage 2 turbo kits. This is the pump that is used with several Unitronic ECU flashes. New design features a Titanium CarboNitride coating, which is a very hard, wear resistant coating. To install, you will simply need to swap pump internals to ones included with this kit. See more here Integrated Engineering Silicone Looking to build a custom intercooler, intake, or turbo charge piping we have the couplers for you. Straight couplers, bends, reducers, bending reducers, and hump couplers available starting at 2" and offered in Black, Red, and Blue. Also, now stocking 3 sizes of vacuum line. see more here. Integrated Engineering Silicone Noise Pipe Delete Cap for FSI/TSI Engines ![]() From the factory, MK5s use a "noise pipe" to bring engine noise into the cabin. Integrated Engineering offers this "noise pipe" delete kit. Utilizing a 4 ply silicone cap and single ear hose clamp, this is the most simple solution on the market. Deleting this pipe has been known to increase throttle response and reduce cabin noise. It also improves the look of your engine bay by removing the ugly factory piece running through it. See more here
__________________
#5 |
Member
2.0T FSI Electronics
![]() Integrated Engineering has a large selection of electrical equipment including, OEM connectors, adapters, resistors, WOT boxes, and standalone systems for your project. Bosch Fuel Injector Plug Kit EV1 ![]() This is a Bosch EV1 fuel injector plug kit. These injector connectors are great for building or rebuilding your wiring harness. This kit includes the plug housing, two crimp-on pins, and the rubber boot to protect the plug. More info here Wiring Connector Pins ![]() These are extremely hard to find pins for most of the vw audi connectors. They will work in crank and cam sensor terminals, injector plugs, most sensor plugs, etc. They are for a 16-20awg gauge wire, and are to be crimped on. These are much better then the precrimped ones from the dealer because they do not require an extra solder or crimp joint to complete the connection, and they let you maintain your wire color all the way into the terminal instead of having the ends yellow like the OEM ones. Connector Pin 20-24awg Wiring Connector Pin 20-17awg 2.0T FSI OEM ![]() Integrated Engineering stocks a huge selection of discount OE parts for re-build and maintenance. This makes it easy for your projects and motor builds as you can buy your performance parts and OE parts in one stop! See our selection here. OE Block Gasket Set for 2.0T FSI Engines ![]() Integrated Engineering has pieced this specialty kit together with all necessary hardware, gaskets, and sealant needed to rebuild your block. See more here Integrated Engineering 2.0T FSI Ultimate Rod Install kit ![]() Integrated Engineering is proud to offer install kits to complement our drop-in connecting rod sets. These kits will help remove any question of what hardware and gaskets are needed for the DIY rod install. This is an ultimate rod install kit for FSI 2.0T engines. This kit includes all components that will need to be replaced when installing drop-in connecting rods in your engine. We have even included a high quality synthetic assembly lube. See more here Integrated Engineering 2.0T FSI Basic Rod Install Kit ![]() Integrated Engineering is proud to offer install kits to complement our drop-in connecting rod sets. These kits will help remove any question of what hardware and gaskets are needed for the DIY rod install. This is a basic rod install kit for FSI 2.0T engines. This kit includes the basic components that will need to be replaced when installing drop-in connecting rods in your engine. We have even included a high quality synthetic assembly lube. Save 20.00 with this kit versus buying the components individually. See more here
__________________
#6 |
Like the look of your parts but would u consider doing some parts in a green as that is the couler I am running with
| Bookmarks |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
(View-All)
Members who have read this thread : 63
| AndrewJB, AwesomeAl, barney2, Bikerz, chris-c, chris1788, Copey, Cupra R, cuprat, cupratdi-matt, dalegolf215, Dan1720v, dooresy, Ed King, evo2345, ForgeMotorsport, gillygilbert, grahams81, ibizacupra, ibiza_1.4tdi, INA, Jambo82, james.l, john_a, jonathanp, korncup, Leonneke, LONZO, lupocharged, mackgold, matt88 lcr, matylad, mgcs1976, michael_77, mosso, mrbdrm, One T, oswal, POPOV, pricey_2k10, R4cup, Rayo_LCR, rev1, RobH, RS777, rsulam, rs_jon, rudolf2, sales@IE, singh123, Smee, splinter_cdo, Squealy, t111bul, The crow, tj_ryait, underpressure, wazza16, wild willy, wotmotorsport, YIN |
| Thread Tools | |
| Display Modes | Rate This Thread |
