Chris Knott
Go Back   SEAT Cupra.net - SEAT Forum » Announcements, FAQs & Rules » ** FORUM RULES & FAQ - Please Read ** » Forum technical problems
Forum technical problems Not sure how something works in the forum? Or have a problem with something related to the forum. Post it in here. ONLY FOR FORUM ISSUES
Reply
Thread Tools Rate Thread Display Modes
Old 09-12-2017, 20:31   #1
Quicksilverline
Newbie
Quicksilverline has 10 points
Side airbag igniter passenger side N200 001 Upper limit Exceeded Intermittant Mil on
On my seat leon 2.0 TFSI Sport MK2 had above code come up when read through vag com. I disconnected the battery negative, disconnected the airbag, seat sensor and seatbelt sensor plugs from the compartment to the left of the seat. Then removed the seat. Replaced all the connectors under the seat with 1.5mm sq spade male and female insulated crimps. As a precautionary measure I used heat shrink to cover all. Refitted the seat and connector plugs but fault came back. I then replaced the plugs to left of seat in floor panel with the same crimps and heat shrink. Fault still came back. Then bought a replacement complete side air bag that fits into the seat. Pulled seat out again, worked the seat lining covers up and replaced the complete side air bag of the passenger seat. Refitted and fault still came back. I then removed the passenger side door panels and found the passenger side crash sensor. Bought replacement from TPS (£50). Fitted this and replaced covers. Reset fault and the re read again. Fault has not come back. Know it’s a long story but had to share as it was a real pain to find. Hopefully I can save someone else the struggle I had. Note always disconnect the battery negative when wiring in your air bag system, also do not wear any clothing that generates static electricity. All this work done cost me less then £100 and my car is now fault free. Good luck and always take care when carrying out your own repairs. I accept no responsibility in any way and this post is a reflection of my own experience only
Quicksilverline is offline   Reply With Quote
Reply
Bookmarks
« Previous Thread | Next Thread »
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
(View-All Members who have read this thread : 4
DavidD, kazand, Leonmb, Quicksilverline
Thread Tools
Display Modes Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Website © 2014 SEATCupra.net
Disclaimer: SEATCupra.net is not an official SEAT site and is not affiliated to SEAT in any way. Visit the Official SEAT Website.
SEATCupra.net are not directly responsible for information which maybe posted in this forum.
All content is viewed and used at your own risk. We do not warrant the accuracy or reliability of any of the information.
The views expressed herein are those of the individual contributors and not necessarily those of SEATCupra.net or SEAT
All trademarks and copyrights remain property of their respective owners.
