Tubular strut braces, either upper (between shock absorber towers) or
lower (at the front of the subframe) will resonate. Which is natural as they are springy metal enclosures under tension.
Resonance will increase the noise and vibration by a small amount, which is more noticeable in Diesel powered cars. People say vibration means the chassis is more rigid, but it's the other way around, the bar becomes a spring. If the bar is aluminum, which has far less elastic modulus than steel, vibration is less, but still present.
To decrease vibration and noise in the cabin, the strut bar has to be dampened. This way, from a spring, it becomes a damper.
The simple solution is to drill a 6mm hole in the bar and fill it about 3/4 with grease using a grease gun. The seal the hole with a small bolt. The whole job takes less than 1 hour.
Example:
Rear tubular strut bar, between rear shock absorbers' towers, aluminum, less than 2 lbs bar weight. (Once fitted, the rear frame near the back seat turns into a trapeze from the original U-shape.)
Used a smartphone and the
Vibrations! app to measure.
Tap the bar with a small rubber mallet, it generates a mechanical vibration of 12.4Hz.
Drilled a small hole, screw a grease nipple, filled the bar with 140°C bearing grease (about 1 lbs weight), removed the nipple, sealed the hole with a small bolt. Tapped again with same rubber mallet, the frequency of the vibration dropped to ~5Hz and loudness was far less. The difference could also be heard while running on rough ground.
Did the same thing with front subframe rear braces (
Audi TT tubular steel). The slight metallic buzz heard at 5000rpm in 2nd gear decreased in intensity to nearly inaudible, decreased in frequency to a deep whirr.
Cost: 2 tubes of grease + 1 nipple + 1 bolt = 5 GBP
