Brake lights and p0571
Dowson1993
81
Had a brake light out replaced it with an led alternative now cars pinged a p0571 fault code anyone had this issue before?
P0571 being cruise/ brake switch (A) mechanical failure
tanto
101
21
sounds like a canbus error have you checked that the led light in compatible with the car as the Leon light is a break and tail bulb and the if you are using led in the Leon you should use one which is canbus error free
Dowson1993
81
Leds are working properly just causing flashing glow plug light is all think I might need to solder some resistors in place
