Isn't the auto stop start button down by the gearstick? I'm sure it is on mine.
Hey Guys,
I have a Pre-Facelift 1.2TDI eco, the Start stop button is above the Cigarette lighter, not on the centre infront of the gear stick, i'm sure if you find a breaking yard with an Ecomotive you'll be able to nab the whole assembly, i've had my cigarette lighter out before and the start/stop button is literally just two wires so i'm sure it can be changed really easily
Hope this helps
That's very helpful. Only if I had a part number, it would make locating it a lot easier.
Hi mate, I've been looking for the same thing! That part number is 6J0905218A for the small start/stop button. Bit of a pain that they didn't make a set of buttons with the start/stop below the hazards, but it looks like SEAT reserved that space for the Passenger airbag only.
May come in handy for you, there's a part code catalogue for the MK5 ibiza. It has every variation of items under the sun:
realoem.me/Seat/E/IB/2015/743/R/9/941/941050#10
Hope this helps, even if the post is slightly old!
-Josh
Hi,
Anybody know a way to relocate the start-stop button so that a 2-din headunit can be installed in an Ibiza 2014 FR model? I have found the part to move the hazard warning etc, but can't find any information about moving the auto start stop switch.
Driver
Hi,Hi,
Driver
Hi,
I am trying to do the same thing with my FR. I have found the small stop start button to relocate it but my only issue is what wiring do I need to connect this?
Any advice would be great?
From seeing where other people recommend I was planning on relocating it above the cigarette lighter. The panel in front of the gear stick only has one connection so I am trying to find a way to get the cables to the relocated button.Where are you going to relocate the start-stop button to?
Yes I will do.Are you going to make a hole on top of cigarette lighter?
Well I’m at the point where I need to sort out the wiring. I was wondering if you had to buy a sedate adapter/harness to get it to work?Okay, let me know how you get on.
