There cheap, easy to work on. Take about an hr at most with zero skill. Saves you an hr labour and it brings you closer to the car. Blood will probably be shared between you two and bad language from you but..thats part of the fun.Oh and also forgot was looking at the engine and it looks like the rocker cover gasket will need changing because there is a slight leak towards the back of the rocker cover and upon cleaning inspection it looks oily and dirty so I thought I would clean it and take away all the dirt and start the engine for about 10-15 minutes and Rev it a little and it slowly leaks out every 15mins a little bit comes out.. Been quoted £90 for that. How comes you guys love these cars so much when they need work all the time? If that's what your sayin? So atm I probably have a bill I'm about 300 400 to fix everything
Sent from my SM-A320FL using Tapatalk
