Moving Auto Start-Stop button
Driver
52
UK
Hi,
Anybody know a way to relocate the start-stop button so that a 2-din headunit can be installed in an Ibiza 2014 FR model? I have found the part to move the hazard warning etc, but can't find any information about moving the auto start stop switch.
Driver
bcr5784
235
Can't you get a (blank?) switch for one of the other spare slots and somehow put a meaningful graphic on it?
PeterA
48
I'm sure there's a few versions of the switch pack,see if your local dealer will look the part up and see what the different options are
Driver
52
UK
photostream
Following intense googling, it seems a possible solution could be this. Anybody know the part number or where to get it from?
MIH11MI6
20
Norwich/ Crewe
Hey Guys,
I have a Pre-Facelift 1.2TDI eco, the Start stop button is above the Cigarette lighter, not on the centre infront of the gear stick, i'm sure if you find a breaking yard with an Ecomotive you'll be able to nab the whole assembly, i've had my cigarette lighter out before and the start/stop button is literally just two wires so i'm sure it can be changed really easily
Hope this helps
Driver
52
UK
Hey Guys,
Hope this helps
That's very helpful. Only if I had a part number, it would make locating it a lot easier.
joshuatk44
Hi mate, I've been looking for the same thing! That part number is 6J0905218A for the small start/stop button. Bit of a pain that they didn't make a set of buttons with the start/stop below the hazards, but it looks like SEAT reserved that space for the Passenger airbag only.
May come in handy for you, there's a part code catalogue for the MK5 ibiza. It has every variation of items under the sun:
realoem.me/Seat/E/IB/2015/743/R/9/941/941050#10
Hope this helps, even if the post is slightly old!
-Josh
Driver
52
UK
-Josh
Cheers mate. I’ve been trying to find a way for years, but haven’t got anywhere yet.
May 18, 2020
Hi,
Driver
Hi,
Driver
Hi,
I am trying to do the same thing with my FR. I have found the small stop start button to relocate it but my only issue is what wiring do I need to connect this?
Any advice would be great?
Driver
52
UK
Hi,
Where are you going to relocate the start-stop button to?
May 18, 2020
From seeing where other people recommend I was planning on relocating it above the cigarette lighter. The panel in front of the gear stick only has one connection so I am trying to find a way to get the cables to the relocated button.
