Has my turbo went pop
Scottmcl
Hi all I’m looking for a little bit of advice
Car has been running in limpmode I thought it was to do with a leaky hose have tightened up the hose still the same had a look in the hose that connects to the allard dpf delete and there is a bit of oil in there does this mean the turbo has ended its self??
If not anyone have an idea what it could be oh and the n75 valve has been changed as well
verbal_kint
639
31
North West Kent
p0230 p0489 and p0243
0489 concerns an issue with the EGR, the other 2 are for Fuel pump and wastegate/actuator.
When several codes pop up at once it can often be a fault with the electrical system and causing the wrong message to get to the ECU which then panics and presents you with limp mode.
You will need to clear the codes then start finding when you can replicate the problem, when driving does overloading the electrical circuit trigger it. It could be a bad wire or vacuum solenoid or solder welds in the ECU gone bad.
Hedgehog Dodger
263
Has my turbo went pop. I dunno but I have spoken proper england since me was a children.....sorry couldn't resist!
