ibiza/cordoba 93-99 service indicator system
Fl@pper
Jun 19, 2001
12,370
26
Gloucester
SERVICE INTERVAL DISPLAY
the computer has counters that not only count the miles from the speedo but also
a time count as well
Displays:
IN00 - No service is required - standard display
OEL - When 7500 miles has been reached before the yearly service is required
IN01 - Indicates time for the yearly service inc oil change
IN02 - Indicates it is time for the Major service
TO RESET THE INDIVIDUAL COUNTERS
1- turn on ignition (do not start)
2- Press the trip-reset button button on the speedo (the trip value will not reset to
zero but will reappear when the procedure is finished)
3- Turn off the ignition and thne release the trip-reset button
In the LCD display you will see the word "OEL"
Using the minute set button for the clock (lower one) you will reset the OEL interval
counter
press it - hold - release - 5 horizontal lines will appear in the display
4- press and release the trip-reset button
In the LCD display you will see "IN01" repeat step 3 to reset the inspection counter when required
5- Again press the trip-reset and rest the "IN02" counter if necessary
If doing an oil change only reset the "OEL" counter
If doing an inspection service reset both the "OEL" and "IN01" counters
If doing a full service reset all 3 - "OEL" "IN01" & "IN02"
6- Turn on ignition (do not start the car)
7- After the appearance of the "IN00" display turn off the ignition
8- You are done - the trip counter should read as it did before you started
PROGRAMMING THE INTERVALS TO REQUIREMENTS
With todays higher spec oils and/or peoples need and desire to service more regular there is a way
to alter the counters to your prefered settings (within reason)
1- Turn on ignition (don't start the car)
2- press the trip-reset button also press the Minute set button on the clock (lower one)
3- The LCD display "OEL 1,S" where the "S" indicates SET
4- Using the trip-reset button you can call up the following counter data in sequence
OEL 1,S - Distance counter for oil change (7500 standard)
OEL 2,S - Time counter for oil change (12 months)
IN 01,S - Time counter for yearly service interval (12 months)
IN 02,S - Distance counter for full service (15000 miles)
5- Using the minute SET button on the clock (lower one) you can display the current value
repeated pressing of the button will select a subsequent lower value and at the lowest level
will reset to the highest and start to decrease again (so don't panic)
the steps work in miles (500 at a time) and time steps in bi-monthly (1=2months) i.e.1-2-3-4-5-6
6- Once you have set the counter to the value you require - turn off the ignition
7- Job done :)
additionally a visual "how to" with thanks to Dinky Dave - cheers
"OEL" Oil Service
IN01 - Inspection Service
IN02 - Inspection Service
BEARDY
Displays:
counter
7- Job done :)
any spelling mistakes or errors drop me a line as i'm crap @ proof reading - lol
MINES ON INS2, SO MIGHT GIVE THIS A TRY.
rich.h44
Its a secret!!!!
Aug 31, 2007
1,601
hull
I did it its real easy,saying that my mate whos a grease monkey waz telling what to do!lol
flubba-jubba
ive got an IN02 flashing up on mine....ive just checked the haynes manual and it looks pretty straight forward (change spark plugs etc) ...... do you reccomend i do the service myself or should i take it to a garage??
Dave_R
Save a Sheep...Buy Brembo
Sep 20, 2004
3,666
South Wales
Ha! I'd just stickied the thread you posted Dave.
Of out to reset mine now! :D
lol I removed it because I saw this one after I posted mine so thought it would be better in here :)
Don't know if you would like to edit the bottom of Flappers to include this bit at the top, know what some people are like when searching lol
p.s. I'm loving Autodata :D
Dave_R
Sep 20, 2004
3,666
South Wales
lol Just gotta do mine but will follow Flappers because "IN02" been flashing for about 4 years now :whistle:
Glad I can be of service Dave.... I will keep looking on Autodata and see what else I can nick :funk:
Fl@pper
Jun 19, 2001
12,370
26
Gloucester
i was just gonna say look who's robbed a copy of autodata :):) lol
cheers for the pics - ill add them in the top if thats ok ?
about time it was updated - 5 years old this thread now :S
mascolo99
thnks I didnt know I can program it!! I used to erase to in 00 only.
tks
Finan
i went jap.. :O
Jan 18, 2009
908
Eíre
bebo.com
Hey Can Some Help?
What do i need to get for a MAJOR Service?
im getting IN 02 on my dash clocks :(
Finan
i went jap.. :O
Jan 18, 2009
908
Eíre
bebo.com
Would this trick work on Polo's?
My Polo is Saying Service Needed but i just got it serviced, i know the dealers would do it but they'll probably charge :|
Fl@pper
Jun 19, 2001
12,370
26
Gloucester
would have thought so especially as it's where the system likely came from anyway :)
Michael Knight
i have a mk2 ibiza 1.4se with no rev counter and a big clock instead
how do i turn off the sevice light?
