Alternative pedal box fix. Easy, quick, free and tough.
deajam
28
My alternative pedal box fix.
This works even if your pedal box is cracked and broken, as long as the main structure that bolts it to the car is ok.
Time taken: few ours after work.
Money spent: £0.00p
Tools: 10mm & 13mm socket and somthing to make a 17mm hole with
!! Firstly it is wise to cheack you can reset your self adjusting clutch cable. Took me 2mins and was simple !!
Re-setting the cable:
Unhook the cable from the gearbox. Now press the pedal all the way down then pull back up. Now go under the bonet and pull the cable (not the outer, just the wire) and the rubber adjuster should compress and your cable will get longer. It should now be too long to hook on to the gearbox. If not try again. Once it has reset put the white clip on the adjuster to hold it shut until after the job had done.
The main job:
All the trouble comes from the fact that the cluch cable mount can't take the strain of the clutch and eventually snaps. My solution was to remount the cable the other side of the bulkhead on a home made steel plate. Problem solved.
It may be best to view the area your working with, this is where the clutch cable enters the cabin through the firewall. It's behind the wiper motor. So take off the wipers, plastic cover under the windscreen and wiper assembly. Note there is a small pug under the wiper motor that you may not see at first. Takes 5mins.
In this pic, just to be clear, the upper area is behind the wiper motor where you've just uncovered and the lower area is above the clutch pedal in the footwell.
Now unhook the cable from your foot pedal, bit hard but try and lay upside down and use a torch and unhook it. Take out your glovebox and the small footpedal cover if needed (one screw each side.)
Back under the bonnet you will now be able to pull the cable assemble entirely out of the cabin through the firewall, including the pedal hook, and see the tubular mount still left attached to the pedal box through the hole.
Now for the plate:
Firstly I found small 5mm thich scrap steel plate about 60x80mm and drilled a 17mm hole near the bottom edge and bolted some spacers on the back edge. (See fig 1)
Any old bit of metal will do as long as it's strong and fits. The spacers are to raise the plate to the same angle as the OEM clutch cable mount on the pedal box. (The plastic tube you pulled the clutch cable out of).
Final dimentions are up to you as I didn't measure anything I just made it by eye.
Mounting the plate
Pull the rubber gromit off the clutch cable, cut a bit out the middle and put it back in the hole in the firewall with the OEM cable mount just poking through. This will stop fumes or damp.
Next feed the cable through the new plate until the plastic guide mounts securely in the 17mm hole.
Feed the cable back through the fire wall and old mount in the pedal box.
Finishing up
Make sure to olny re-attach your clutch cable if you have reset it or it will be too short.
Attach both ends of the cable before unclipping the white plastic thing. Now pump the pedal slowly 5 times to take up the slack. It should feel like a new one.
Make sure the car moves and the clutch works at this point and then put everything back on the car.
Done.
Please leave feedback or alterations.
Hope this is of some help to you guys.
eagerb
Just registered to add some thanks for this useful post - after being quoted between £400 and £650 to supply & fit a new pedal box, I thought this was worth a try - I didn't really fancy the job of replacing the pedal box myself (also, the new part costs over £100).
This really is an easy job and works very well. Just some additional notes from my experience:
- My clutch cable doesn't seem to be an adjustable one, at least I couldn't see anything that looked like what was described, so I skipped the part about resetting it. I just loosened the double nuts at the end, and unhooked the cable at the engine and the clutch pedal. Refitting at the end of the job was no problem. When the job was done, the adjusting nuts were only about 5mm further down from their original position.
- You need to remove the windscreen wipers and all of the plastic trim below the windscreen (it's obvious, but no harm in saying it). The plastic that seals against the windscreen glass is held in by five or six metal clips and needs a bit of force to lever it out but it does pop free. (Refitting it is a bit awkward too.)
- I had a bit of 3mm thick stainless steel plate lying around which was perfect for the job, however drilling the 17mm hole for the cable was a pain because I only have an 8mm drill bit and filing the hole up to 17mm with a rat-tail file was hard work! If you can use mild steel it would be easier but the plate is going to get wet, so think about rust.
So far the job is looking sound and the clutch feels like new again. Thanks very much for taking the time to post all the helpful advice and diagrams.
Daniz
Please tell me this can be done on the 6k2's? As mines about to go and i thought this exact thing , but im unsure if theres access to the back of the hole in the bulkhead!
Cheers Danny
