Chris Knott
Go Back   SEAT Cupra.net - SEAT Forum » SEAT Model Specific Discussion Forum includes Members Projects » Leon » Leon Mk2
Leon Mk2 For all topics relating to the Mk2 Leon
Reply
Thread Tools Rate Thread Display Modes
Old 27-12-2017, 22:57   #1
Oldlandsam
Newbie
Oldlandsam has 10 points
Leon Tfsi fr. high pressure fuel pump connector problem
Hi, I can’t post links to images yet but basically the circle connector thing at the top of my high pressure fuel pump is cracked, ocastionnaly my epc light comes on and the car has no power until I take the engine cover off and push it back together. Does anyone know if you can just replace the connector? Or the top part of the pump? Or will the whole thing have to be replaced? Thanks
Oldlandsam is offline   Reply With Quote
Old 28-12-2017, 14:45   #2
2a1n7867
Newbie
2a1n7867 has 10 points
for temp fix you can glue it
happened on my car it is caused by the engine cover coming loose and hitting the connector causing it to crack
and will need complete unit replacing as nobody sells the top part seperatly
2a1n7867 is offline   Reply With Quote
Old 28-12-2017, 14:52   #3
Oldlandsam
Newbie
Yeah my engine cover mount is completely snapped off, I guessed that’s what’s caused it. Got new mounts on the way. Was thinking of glueing it but didn’t know how hot it gets and how the glue would react. Thanks.
Old 28-12-2017, 15:28   #4
2a1n7867
Newbie
you can glue it with superglue and i did the same to mine with just superglue and drove it over 100 miles atleast and was running fine but changed the pump to be on the safe side
Old 28-12-2017, 16:40   #5
Oldlandsam
Newbie
Okay I’ll give that a try and start looking for a cheap second hand pump. Thanks for the help
Old 28-12-2017, 20:29   #6
Oldlandsam
Newbie
Just looking at fuel pumps, do you know if I have to get the exact same part number? Mine is 06f127025h but would 06f127025k or d fit for example?
Old 29-12-2017, 09:17   #7
2a1n7867
Newbie
You need to get the latest revision which 06f127025M not the old ones
Old 31-12-2017, 14:49   #8
Leericho
Newbie
Leericho has 10 points
Mine is also cracked, don't think its causing any problems at the moment.
Although it sometimes runs a little rough on idle but the down pipes blown also so that maybe contributing
Ive got the CEL light up too but haven't had a chance to scan the code as im away at work
Ive got a new pump coming, is it easy to swap over the auto tech internals?
Leericho is offline   Reply With Quote
Reply
Bookmarks
« Previous Thread | Next Thread »
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
(View-All Members who have read this thread : 9
2a1n7867, Darbo, Hawkers, Jfox, kazand, Leericho, Oldlandsam, richicupra, Rusty2k
Thread Tools
Display Modes Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Website © 2014 SEATCupra.net
Disclaimer: SEATCupra.net is not an official SEAT site and is not affiliated to SEAT in any way. Visit the Official SEAT Website.
SEATCupra.net are not directly responsible for information which maybe posted in this forum.
All content is viewed and used at your own risk. We do not warrant the accuracy or reliability of any of the information.
The views expressed herein are those of the individual contributors and not necessarily those of SEATCupra.net or SEAT
All trademarks and copyrights remain property of their respective owners.
