Mirror fold problem
omardrissi
21
Manchester
Hi Everybody,
I have a problem with to fold my driver side mirror. the passenger is working normally,
this is happen when I change my battery.
in the begininng it folds halfways, now it is completly off.
I still can adjust the mirror, the problem is only to fold it.
Any hints. thank you in advance
Miguel 7
R ST
Jan 23, 2017
350
56
28
Hi
Went through the same recently
Had to replace the mirror as the motor inside was faulty
If you end up replacing it, dont do it at the dealers :) Quoted me £360 and I've done it for £70, easy job
Seems to be a more common problem I've heard about this 3 times now ..
omardrissi
21
Manchester
Hi
Thanks Miguel 7
I will try to find a second hand one on ebay
Miguel 7
R ST
Jan 23, 2017
350
56
28
Make sure you look for a 8pin as there is lots 6pin which are non power folding
Before buying check yours, connections, etc
I could hear mine which was trying to fold but the motor wasnt actually moving so after some research I found out it wasnt repairable
