Can I put a ibiza from tdi gearbox into my cupra tdi
tommyd
18
After spending today trying to find a new/recon box I'm wondering can I put a golf gt tdi or ibiza fr gearbox in instead? Didn't realise the guc gearboxes were so rear. But suppose the cupra tdi is a rear machine
tommyd
18
Will it be able to cope with a slight gain in power. It's had stage 1 so roughly 190bhp? I'm not bothered in the short shift really
Big-Pete
Always on the Limit
Aug 8, 2010
3,032
any PD 160/130 box should fit.
160s have shorter ratios for better 0-60. 130s are longer- read less rpm for same speed ie 70mph = 2100rpm in my 160 vs 70mph = 1900 in my mates vrs (pd130)
tommyd
18
Out of interest if I sold my box as scrap it must be worth over 100 squid. There like rocking horse ****
tommyd
18
Badger. I've removed the gearbox and I'm I've seen a erf bora pd 130 6 speed box on e Bay. Will this be ok to put in the cupra
tommyd
18
This bora gearbox has been a nightmare to put into the cupra. The gear shaft needed to be removed but now I've found the mounts are totally different. I'm thinking would ibiza fr tdi mounts be needed
tommyd
18
After some cutting of the original gearbox bracket I've managed to get the box into the cupra. After bolting everything together was exited to get her back on the road only to find a very notchy steering in only one position. So stripped down the pump to get to the plugs to test the voltage. Do I need a certain voltage for it to work Correctly?
