Passenger window won’t fully close - solution
Goodolpete
21
Hi,
had to call Seat rescue out as I’d lowered the window, and when I tried to close it,
it stopped one inch from the top. No amount of up and down of the window would
make it go higher. The guy arrived, I explained the the problem, he said he had to
reset the window. He opened it fully, then pressed down on the switch for five sec.
When he pulled the switch up, the window went right up to where it should be.
The reset tells the window “this is the bottom, go up from here” (if that makes sense).
