k1 cupra handling..?
mob33n
i own a k1 cupra and i have to admit the handling on the car is good but wen i throw the car in to corners the back always drifts out alot its easy to control but i just wanted to find out if any1 elses cupra does this?
mob33n
esp's on sometimes had it off once yeh i think ur ryt i throw it in alot because im used to the r32 4 wheel drive system i used to own 1 before on the way home from work ill try it smoothly round corners see how it goes
Mar 30, 2008
621
Edinburgh
the FR's have a fairly loose rear end as well. Mine felt a bit loose when taking fast corners, without chucking the car into the corner. The rear end would a bit twitchy. you'll really have to change part of the suspension set-up to correct this. I've got mine lowered on coilover and thicker ARBs (front and rear) and it now corners high speed corners without a twitch.
Probably the best starting point is thicker ARBs. not that expensive too.
Poverty
slow in fast out.
Seen how my mates drive their r32s and new s3 and its all balls out round corners due to the immense grip.
