Seat Leon Clicking When Starting
kiteboywales
Hi all....my car has been outside for about 3 weeks while I await a new wing mirror which someone knocked off
In the mean time I tried to start the car other day and it's making like a ticking noise when the ignition is turned.....
It's absolutely dead too ....the doors won't open on central locking etc.....so assumed battery was close to being flat
After buying a chargerwhich said the battery was full I just checked with a multimeter and the battery is full
Any ideas what the issue maybe anyone....im assuming alternator but no clue really
It's a tdi 1.9 also
Thanks all
Sent from my SM-G955F using Tapatalk
kiteboywales
Battery terminals were on tight.....didnt have grease when I changed the battery last time though....but look fine
brian1912
73
Definitely sounds like the battery have you tried a jump start
kiteboywales
No not yet....not sure if true but I'm not sure if ive heared your not supposed to jump start diesels....maybe a myth don't know
brian1912
73
I start diesels machines at work all the time not sure about a car right enough
steveh8204
78
I've just tried to start my car and it sounded like the battery was flat even though it had only been off twenty minutes. A few seconds later there was a very fast licking noise. Is this most likely the solenoid in the starter.
I managed to jump start it straight away when I connected to my wifes car so does this mean its more likely the alternator. Gonna test with my multimeter tomorrow when I get a chance.
