Chris Knott
Go Back   SEAT Cupra.net - SEAT Forum » SEAT Model Specific Discussion Forum includes Members Projects » Ibiza » Ibiza Mk4
Ibiza Mk4 For the 2002 - 2008 model
Reply
Thread Tools Rate Thread Display Modes
Old 04-06-2011, 01:15   #21
Blanco92
www.racedriversinc.com
Blanco92's Avatar
Blanco92 has 20 points
Quote:
Originally Posted by Chris_a_73 View Post
Am I right in thinking, that I only need the pair of Cupra bushes? My friend is going on about me needing new lower arms as well, 'as it's easier to do the whole thing'. I'm pretty sure it's just the bushes that need doing......
The lower arms is just the lazy way of doing it, yes you can change them and it isn't very difficult, but any labour costs you save by changing the arm, you end up spending it to buy the arms!
Don't forget on top of the fitting cost, the tracking will need to be checked and adjusted if necessary.
__________________
Chris.
My Glacier Blue Ibiza Mk4
Blanco92 is offline   Reply With Quote
Old 04-06-2011, 01:20   #22
Chris_a_73
1.2L Ibiza Mk4 '07
Chris_a_73's Avatar
Chris_a_73 has 10 points
Ah okay cheers mate. I'll check the price of the arms with David @ Sere. If it's significantly cheaper to do, I'm all for saving some dosh! Asked my mate at work who knows a few mechanics, so hopefully will get a cheaper quote..
__________________
Chris_a_73 is offline   Reply With Quote
Old 04-06-2011, 01:27   #23
Blanco92
Blanco92's Avatar
Other thing to bear in mind is any new arms you get will need to have the Cupra bushes on them already, just renewing the standard ones doesn't work, they'll be shot again in 20k miles. I don't think this will be an issue though because I'm quite sure you'll find it's cheaper to just change the bushes.
__________________
Chris.
Old 04-06-2011, 01:30   #24
Chris_a_73
1.2L Ibiza Mk4 '07
Chris_a_73's Avatar
Quote:
Cool cheers. I want to upgrade to Cupra bushes anyway, for the better handling.
I'll probably have to shell out £180 ish for the bush fitting, and then another £25 for tracking..
__________________
Old 05-06-2011, 14:07   #25
Armitageshanks
Armitageshanks has 10 points
Hey ,
I've got all the tools for fitting cupra bushes as per Briskoda guide, if you wanted to diy like me it would only take a few hours. I kind soul on there made me up the spacers for extraction and insertion of bushes for beer money really.
Im no mechanic ,but with the right tools this has a Haynes spanner rating of 2 or 3 max. There are no tracking issues as its all done with bush console on car.
Armitageshanks is offline   Reply With Quote
Old 05-06-2011, 14:58   #26
Chris_a_73
1.2L Ibiza Mk4 '07
Chris_a_73's Avatar
I don't really have the knowledge nor confidence to do that myself to be honest.. Will be happier to just pay someone to do it for me!
Plus I don't have the proper tools for the job :/
Anyone in the South East who can help, I've got some cash waiting for ya!
__________________
Old 05-06-2011, 15:41   #27
adzy91
Banned
adzy91 has 10 points
Seat quoted me £235 parts and labour inc VAT. Got it down to £155 inc VAT and got an Ibiza Mk5 FR Tdi courtesy car, so not bad!!
adzy91 is offline   Reply With Quote
Old 05-06-2011, 15:51   #28
Chris_a_73
1.2L Ibiza Mk4 '07
Chris_a_73's Avatar
How on earth did you haggle it down to that?!
__________________
Old 05-06-2011, 17:00   #29
adzy91
Banned
Magic mate, i wernt happy with some previous work they did, so they gave me a 100% credit note against it. Proper good service!
Old 05-06-2011, 17:26   #30
Chris_a_73
1.2L Ibiza Mk4 '07
Chris_a_73's Avatar
Dammit, I was hoping there was a trick I could use
__________________
Old 05-06-2011, 18:50   #31
Blanco92
Blanco92's Avatar
Quote:
Originally Posted by Armitageshanks View Post
Hey ,
Yeah it can be done on the car if you have the right tools, most people take the wishbones off though for ease of fitting. And if they haven't got the correct tool. I tried making a tool up but wasn't having much success with it.
__________________
Chris.
Old 18-06-2011, 14:10   #32
conno11y
Posts: n/a
I've bought replacement OEM bushes as a temp replacement until I get some Powerflex or Cupra bushes. Been a weak point on both ibiza's that i've owned.
I took the wishbone off then used a homemade tool that pulled them out after heating the wishbone a little.
Old 18-06-2011, 15:29   #33
Chris_a_73
1.2L Ibiza Mk4 '07
Chris_a_73's Avatar
Would you be able to tell me how to make the homemade tool? I'm up for trying to do it myself, to save £150
__________________
Old 18-06-2011, 19:22   #34
conno11y
Posts: n/a
I can't yet make URL Posts so put this together with HTTP in front. It's a guide to make the tool
briskoda
.net
/forums
/topic
/92625
-fabia
-wishbone
-bush
-replacement
-diy
-guide/
Old 10-01-2018, 17:33   #35
Cuprar72
Cuprar72 has 10 points
what size are the anti roll bar bushes on 04 plate cupra r bam, i replaced mine with standard but the ones i took out had a broken plastic piece i think went inside rubber but new ones didnt come with it, so i want to uprate them as i noticed that when its jacked up one side theres a gap between bush and arb but not when its on the floor
__________________
Miltek Sports cat back, forge 008 dv, pipercross panel filter, forge PCV hoses!
Cuprar72 is offline   Reply With Quote
Old 11-01-2018, 11:27   #36
Chino_UK
Team Creatine
Chino_UK's Avatar
Chino_UK has 10 points
Quote:
Cupra R? Do you have a Leon? But if it's anything like the Ibiza's, the older version of the ARB had a plastic sleeve as part of the bar which cracked off the ARB over time(usually as the bar rusted underneath and broke it off), and the bush was no longer a snug fit, resulting in the ARB having to be replaced with a the revised one (no plastic parts).
__________________
APR Stage 2 Progress Thread: http://www.seatcupra.net/forums/showthread.php?t=230391
Chino_UK is offline   Reply With Quote
Old 11-01-2018, 11:38   #37
Cuprar72
yes leon cupra r and yes had plastic sleeve which broke off, what about if i polybush them? just need to measure bar see what thickness mine is, sounds daft if i have to replace whole bar tho
__________________
Old 11-01-2018, 11:38   #38
Cuprar72
my bad just realised this is an ibiza post , sorry
__________________
Reply
Bookmarks
« Previous Thread | Next Thread »
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
(View-All Members who have read this thread : 108
00Rupert, 1000baird, aaronipswich, adzy91, AP2000, Armitageshanks, attila_tdi, Badger, barney501, barneystuta, BeatJumper, BeezaDave, beezanick, big rich, Big-Pete, binkylad, Blanco92, BloodnutsTDI, Bondiblu, cbr40017, CGD217, cheshire cat, Chino_UK, chrissyboy, Chris_a_73, CluneZ, cordoba lad, corndog, Cos, cupraajy, Cuprar72, cwalte, darkhorse, dash, Dave 20vT, Dazz 1989, DEAN0, denMla, dholdi, Discostew, DSP, ecklad, Elliman98, Fisher, Fl@pper, FR-RUSH, FR_MATT, gdjohny, george130, Gertie, GTTIM, Hargo, higgi, jamie8954, JoeCav, joehirth, joestella28, jon_boi_91, Kernowbeeza, kidinspace, knight85, leighton, louise ibiza re, lugsy, Marmalizer, matthab, Mattwood, matylad, moggytom, Ol' Timer, onesh0t, processpaul, puchos, R3k1355, Rayner1990, Red Panda, redrob0108, rf860, rideonracing, Ronin225, ross p, scottfr, ScrewedSkull, secret.squirrel, seedsy270, Slippery_Stu, Stevo-91, Syy, TAOTAO, tattybits, tcm1106, thatguycraig, Tigertim001, tl22, Tom0StarC, tomhowroyd, tomo336, Tompy77, Vasily87, veloc123, vroomtshh, w.reid306, Warning, Weedall, Wilson9, wrayvon, xX usher Xx, Zsaba
Thread Tools
Display Modes Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Website © 2014 SEATCupra.net
Disclaimer: SEATCupra.net is not an official SEAT site and is not affiliated to SEAT in any way. Visit the Official SEAT Website.
SEATCupra.net are not directly responsible for information which maybe posted in this forum.
All content is viewed and used at your own risk. We do not warrant the accuracy or reliability of any of the information.
The views expressed herein are those of the individual contributors and not necessarily those of SEATCupra.net or SEAT
All trademarks and copyrights remain property of their respective owners.
