Seat Sport Cupra brake caliper info
RobDon
Pro Detailer
Situation is this: Car is a Cupra but only has standard 312mm brakes on it. I'm guessing at some point the AP calipers seized up so rather than having them refurbished or buying new calipers a previous owner removed them and put standard calipers on.
I have sourced a pair of AP calipers, I've sent them off to be fully refurbished. When I get them back I just need to know if I need anything else to fit them onto the Cupra?
rolphy
21
thanks for this info ive got this to attempt in the next few weeks hoping that the pins come out don't fancy a whole weekend to do whats usually a half hour job..
andy1bmx
12
Cant find caliper parts
Hi,
I having a real struggle finding a company who sells most the parts for the caliper.
I have found a company called Auto Performance Products
This is the link to the parts for the caliper a-pp.com/Catalogue/Car-Specific/Seat/Seat-Sport-Calliper-Repair-Parts[/url]
I need the Fluid Brige Pipe CP6607-29CR3 but they don't have any in stock and I can't find any other company who does have them.
I have tried to contact them to ask when they'll be in stock but I've had no reply.
Does anyone know another company who sells these parts?
Scotty33
18
Demon tweeks carry AP spares, had to get some ordered for me, but came through with everything I needed.
Scotty33
18
A few pics confirming part numbers and prices. The seal kit contains 4 piston seals, 4 dustboots, 2 bleed nipples and 2 small o rings which I have yet to work out? Basically one side.
Demon tweeks held the order back waiting for bleed nipples, that I ordered individually, neither of us realising they are included in the kit!
Sent from my E6853 using Tapatalk
Big-Pete
Always on the Limit
Aug 8, 2010
3,032
Item number Item name Quantity required
CP3160-106ST SCREW-M06x012 BUT 4
CP4949-114 SEAL PISTON-1.50 STD 4
CP4970-124 SEAL O/R-08.10x1.60 2
CP4970-125 BLEEDSCREW-M10 (O/RING) 2
CP4970-133 BLEEDSCREW CAP-RUBBER 2
CP5200-124 RETAINERPAD-M08x064.6STL 2
CP5555-156ST BOLTMC-M08x092 CAP 2
CP6200-103 WEARPLATEN17.0x1.20 4
CP6200-104 PISTON-1.50x38.1ALU-DRT 4
CP6200-114 SEAL DIRT-1.50 4
CP6607-124 CLIP ANTI-RATTLE 25DISC 1
CP6607-29CR3 PIPE ASSY-213xM10 1
CP7600-109 PAD RETAINING PIN 095. 2
