I have had my roof wrapped for maybe 2 years or more now.
Does anyone know if I was to take this off would there be damage to the paint?
If so how would I get it looking its best again?
It all depends if you garage the car, the brand of the vinyl and the condition of the paint before you wraped it.
The best way I found is to elave the car toasting in the sun for a few hours or using a heat gun and remove it with patience to avoid leaving much glue residues in the paint.
If there's much glue after you remove the vinyl, use a bit of white gasoline, goo gone or mineral spirits with a rag to remove them and wash thoroughly to remove all the solvent from the paint and avoid staining.
Since it's a big section covering the whole panel, there's no need to polish the paint to level the fade on the clearcoat, but you can do it if you feel like it. After a couple of weeks in the sun, there should be little difference on the paint color, and because you have a clear color it's less noticeable.
I really doubt the vinyl will peel the clearcoat unles you used a really cheap material or the roof was recently painted, but there's a 20% chance it had brittle enough to make a pain in the ass to remove since it can break when it's too dry and burnt.
