It’s really easy, you need to remove the part under the window buttons ( hard to pull of but only clips) then two bolts on bottom of door and 2 behind the handle and window. Then you have to pull the door panel up really hard !
After that once detached you have to disconnect door opener cable. Ant there you go 6 bolts for speaker and your set
Are u sure that is so easy?
if u can make a tutorial on ur car if i take u 5 min it will save me 200 euro please
I take door panel off by removing the 4 screws, then it is easy you lift each side of interior panel ( quite hard) and then the other side and there you go.
This way you don’t have to remove window, it is a bit easier I think.
