Still having issues
Seatboy
69
So I did the fan resistor mod
Fans work with aircon on but can't get them to come on there own
Changed green sensor
Also tad sensor
Yesterday plastic flange near tad next to battery broke and blew off changed thermostat other one opened but was slower then new one
Any ideas
Seatboy
69
So issues are tad cold or coolant comming out cold
Fans not working only if air con on they work
Now a burst coolant hose
Tested old thermostat and it does work
If hg was gone would that stop fans working ECT
And same if it was water pump
I'm at a loss here
Alexis27
2,100
453
Manchester
They won’t come on on their own unless you can get the engine really hot though. How are you testing them?
If they both work with air con on they will generally work when the engine goes over 90.
Seatboy
69
I did the resistor mod temp can hit 95 still won't come on
Like I said though temp in tad is cold as when I blew this flange noticed temp of coolant in rad was cold
Seatboy
69
I'm going to buy a compressor test 2moro what readings should I be looking for to rule out hg or head issue's
