Rotary noise from front wheels-wheel bearing?
Jamesenty
68
Got a noise coming from the front wheels in the best way I can describe is like a helicopter! The noise get faster and louder with speed and is more dominant when I’m turning a corner (turning onto motorway slips roads are the worst as I’m at speed and turning). There is no vibration just the noise, could this be a wheel bearing or is it something else?
BJM
739
Houston, Renfrewshire
A humming noise would indicate a wheel bearing. Although it could also just be a characteristic of a worn tyre. A clicking noise, especially when turning can be indicative of a worn CV joint.
Sent from my Moto G (5) using Tapatalk
Jamesenty
68
It’s not a clicking noise, it’s definitely a humming that occurs with each rotation of the front wheels, I know that my tracking was out and it’s just been sorting so my front tyres are a bit unevenly worn, could that cause the noise?
hellooo
76
My Ibizas have both done it. Caused by tyres becoming stepped on inside. Is common on cars with the MQB platform. Remember Whatcar had a Golf on long term test which needed new tyres as a result. Replacing rears shortly as was an advisory at first mot. Roar is noticeable at between 30 and 45 mph.
RUM4MO
7,784
983
South Scotland
Strange, my daughter has owned, from new, an Ibiza SC since November 2009 it has 215/40 17 wheels/tyres and has never suffered from abnormal tyre wear, in fact at its MOT this year, I had been waiting for all seasons tyres to arrive so it still had its old but legal tyres on it, which caused the tester to issue advisories on all 4 tyres though that was due to them almost at the minimum tread depth, well just less than 3mm across each one.
dm222
1,468
46
Same here but with different tyres, no abnormal wear.
Tyres were getting to the 1.6mm mark when I replaced them and the same on both sides.
More wear on the sides, not much, than in the middle though, but thats because I used SEAT specs for tyre pressure, they recommend for confort, now I use more 0.3 bar than spec.
Enviado do meu ASUS_Z017D através de Tapatalk
Jamesenty
68
Just to let everyone know it was a wheel bearing as I suspected, all sorted now, surprising how quiet my car seems now with that noise gone!
adamb87
cupra gone :(
Feb 13, 2011
1,472
Preston
did you sort it out yourself? or did you take it to a garage? think i have a front bearing on the way out. Annoying considering its only done a tad shy of 40k miles.
Jamesenty
68
I wanted to do it myself but didn’t have the equipment for it as the bearing has got to be pressed into the hub so I had a garage do it for me
adamb87
cupra gone :(
Feb 13, 2011
1,472
Preston
ok. just realised our car is still in warranty by around 8 days so its booked in for wednesday to see what they say :)
