Icestorm's hybrid LCR mk1 374.2bhp and 341.8lbft
LongDave
73
Hull
375 out of a hybrid ! Makes me wonder why I bothered going big turbo ha ha.
Love them centre gauges too
icestorm81
504
109
Dorset, Dorchester
2Forge lightweight race wheels in 18x8 have been ordered, will take 2 weeks to arrive. Once all 4 are on the car, I will get rid of the spare and the car will be at least 20kg lighter.
icestorm81
504
109
Dorset, Dorchester
ECS Stage 1 Rear Big Brake Kit - Drilled and Grooved 306x22mm Rotors, with ds2500 pads and 2 brand new real calipers with the carriers painted red have been ordered. My 2Forge lightweight race wheels in ET32 18x8 arrived today, just got to coat them in gtechniq c5 alloy wheel armour before putting on my ar1's and mounting them myself on the car. Pictures to follow when I get time. Car is running 30psi of boost, up from 28 before, will be booked in for rolling road sometime next month, should be close to 400hp.
icestorm81
504
109
Dorset, Dorchester
These are the Ecs Rear Big Brake Kit - Drilled and Grooved 2 piece 306x22mm Rotors with brand new trw caliper and carrier's which are a direct replacement for the factory fitted 256mmx22mm.rotors. Running ds2500 pads with them.
Reactions: Sparkie
icestorm81
504
109
Dorset, Dorchester
Well since I was going to have all my brakes replaced, it was justified to have all new wheel bearings fitted as the car is almost 14 years old. AP Racing 6 pots with 356mm floating 2 piece discs with ds2500 pads and braided brake lines were then fitted along with ESC rear big brake kit comprising of 306mm 2 piece discs, with new trw calipers, carriers and ds2500 pads. Not had a chance to use them properly as I am still bedding them in.
Before
After
Before
After
Andrewwright
Turbo lover
Aug 16, 2016
1,567
224
Peterborough
Before
After
Before
After
WOW. Very nice setup.
Sent from my Nexus 6 using Tapatalk
Reactions: icestorm81
Pew.
1,451
142
Scotland
Might be a stupid question but I'll ask it anyway.....
How does cold air feed to that intake when's it hidden behind the battery like that?
bruceR
2,540
616
Monifieth, Dundee
What a cracking brake set-up that looks , did you have to do any alterations to your master cylinder or reservoir due to the bigger calipers??
Andrewwright
Turbo lover
Aug 16, 2016
1,567
224
Peterborough
Cold air Intake doesn't really matter as the cooler does the cooling before the intake. Intercooler is the most important thing, bigger the better.
