Left rear door locked
Stefot
Hi
My Cordoba 2004 works perfect BUT it is impossible to open left rear door either with key, remote or from inside or outside. Now I decided to fix it but that seems to be easier to say than to do........ After a lot of work I've been able to lift off the inner panel so I can now see parts of the windows mech and the wire to the lock. I have also removed the bolts around the metal plate that holds the windows but now I'm really stuck. I can't really see the locking mechanism or force the lock to open though I can feel and hear that something happens when pulling the wire. Do anyone have experience and solutions what to do, some photos or drawings of the construction would also help a lot ?
bukkake_face
19
Once I was able to disassemble the whole rear right door on my Cordoba 2003 and it took me a while to understand what was going on there. Since your door is locked and you didn't detach the metal wall I recommend you to take out the metal wall and try to pull the steel wire again or to open the door lock with the long screwdriver.
I have some photos here: imgur.com/a/lQPg2
