New Seat Ibiza
c@tiom
Hi, every time I ask google a stupid question I find someone has already asked it several times here so thought I would just cut out the middleman. Bought a pre used Seat 1.2 TSI FR 9 months ago and have broken it already...............off to search the threads of despair :D
c@tiom
Thanks for the welcome ....epc light keeps coming on and knocks it into limp mode. Garage getting a turbo pressure fault have reset it a couple of times but now saying it needs a new charge pressure actuator. Nosing around to see if this is a common fault only had it 9 months and I'm a Seat newbie.
camelspyyder
2 SEAT-er
Jun 26, 2014
1,305
175
Same fault on my 1.2 TSI 105 at 26000 miles.
Charge pressure actuator was the first fix which didn't work in my case.
2nd fix was a new turbo and it ran great from then on.
Luckily the car was still inside warranty.
http://www.seatcupra.net/forums/search.php?searchid=11096661 lists other threads on here about the problem.
There was a service bulletin in around 2012 that was supposed to fix the root cause, but my 2014 did the same thing.
c@tiom
urgh hoping it is the actuator as the cheaper fix has done about the same mileage as yours too but no warranty..........thanks for your welcome will update you all with how it goes if it helps
