Door card removal guide...done in 2 minutes!
Deleted member 77040
cant believe the speakers are riveted in! horrendous never owned a car that has done this with the door speakers.. is it a vag thing?
ye i will do! but just used to gd old screws n i rekon this is easier
lil3520
IBIZA 1.9 TDI SPORT 08
Nov 26, 2006
3,001
21
ALCESTER, WARWICKSHIRE
1) there are 3 torx bolts at the bottom of the door card - undo these.
2) there are 2 big philips bolts behind the grab handle cover - undo these. On the drivers side they might be obscured by the electric window switch...pop this out upwards once you've undone the screws and disconnect the lead.
3) undo all the clips around the door card by getting the bottom of the card and pulling it outwards. Take care with the clips, don't be too harsh with them!
4) bash the door card from the bottom so that it comes apart from the window seal.
5) undo the door handle cable and the mirror adjuster lead.
6) done!
do i need to take the door card off to replace speakers, can just the speaker covers come off ?
Deleted member 89419
Usefull... Now with Focal Performance in the car :)
