2008 Leon tdi 140 pd problems
8valvenut
Hi newbie here thanks for letting me in lol
I'm hoping someone can help me, I recently had a starting problem with my car so put vcds on and came up with glow plug on cylinder 3 faulty and cam position sensor intermittent.
Got some new plugs and a sensor and fitted them over the weekend, then the car wouldn't start and flattened the battery.
So got the jump leads out and it eventually started (with the help of some easy start) but sounded a bit rough and lumpy and there is no throttle at all whatsoever, it only starts if you hold the key in the crank position for ages then fires but like I said sounds really rough and there's no throttle at all.
Living in hope
