Hi all,
I have a 2.0T engine (in an Exeo, but I think this is essentially the same engine as will be in a 2.0t FR) and was doing some VCDS logging.
I did post over in that forum, but it's a bit tumbleweedy over there, so thought someone here might be able to give me a hand with some diagnosis.
Repeating some of my thread from over there:
- Did some boost logging (block 115) - pic below - is this normal?
2nd gear run
and
3rd gear run
- Did some Block 31 lambda on WOT logging (block 31-1) - is this normal?
- logged the n75 (on block 114), but what am I looking for to see if this is ok?
- Also checked for misfires. Now I don't seem to get any on heavy load runs, but it the high gear/low rpm running after a heavy load I do seem to get only a couple... Is this normal or does this point to an issue?
Would really appreciate any comments!
2nd gear run
and
3rd gear run
