Listers - Parts
Go Back   SEAT Cupra.net - SEAT Forum » General Topics » General Off Topic Chat
General Off Topic Chat To be used for subjects of a general nature. NOTE - PERSONAL ABUSE, ABUSE OF THE SITE, ABUSE AGAINST THIS OR ANY OTHER WEBSITE OR ANY COMPANY WILL NOT BE TOLERATED.
Reply
Thread Tools Rate Thread Display Modes
Old 22-11-2011, 21:28   #21
andythom
Senior Member
andythom has 10 points
Of course it was....but thought I'd make it plain simple and easier to understand for our special members
andythom is offline   Reply With Quote
Old 23-11-2011, 15:09   #22
chris285
leon mk1 fr tdi
chris285's Avatar
chris285 has 10 points
well good news for mean as means factory fitted xenon headlights on my next car are not essential then
__________________
revo stage 1, custom cat back twin exhaust, fabia rear wiper, aero wipers and c2 aerial - more to come
chris285 is offline   Reply With Quote
Old 09-12-2011, 13:28   #23
LEE69
Stage 2 Revo'd
LEE69's Avatar
LEE69 has far too many pointsLEE69 has far too many pointsLEE69 has far too many points
LEE69 is offline   Reply With Quote
Old 24-01-2012, 11:43   #24
gac
Troll under ***'s bridge
gac has 10 points
Seems that the original link has been removed, an alternative is here
gac is offline   Reply With Quote
Old 19-08-2012, 22:36   #25
Bashiee
Torque Winning - TDI
Bashiee's Avatar
Bashiee has 10 points
how do you check the beam pattern of hids?
__________________
My ReadersRide on my girl:
http://www.seatcupra.net/forums/showthread.php?t=361880
Get Involved: http://www.facebook.com/xAshMan
Bashiee is offline   Reply With Quote
Old 19-08-2012, 22:57   #26
big rich
VAG techie
big rich's Avatar
big rich has 20 points
with a headlight beam tester
__________________
Genuine Fully registered VCDS/vagcom (hex-can-usb) south and west yorkshire. Fault finding, servicing and repairs.
PM for assistance
big rich is offline   Reply With Quote
Old 19-08-2012, 23:05   #27
Jarre
Senior Member
Jarre's Avatar
Jarre has 40 points
i guess what it means is, if the beam pattern is as good as standard halogens then all is okay! If the light is all over the shop and going to dazzle drivers, no good!
__________________
2008 ED30 #2270 Genuine VCDS - ask if you need help!
2011 SEAT Leon 2.0TDi CR FR+
2010 SEAT Leon 1.2TSi
Jarre is online now   Reply With Quote
Old 19-08-2012, 23:12   #28
big rich
VAG techie
big rich's Avatar
Yeh basically mate, although in my experience they fook the beam up a bit
__________________
PM for assistance
Old 19-08-2012, 23:14   #29
Jarre
Senior Member
Jarre's Avatar
Jarre has 40 points
Quote:
Mine is no different mate!
__________________
Old 19-08-2012, 23:17   #30
big rich
VAG techie
big rich's Avatar
I dont check lights on a garage door when im doing a mot lol
but yours dont look bad tbf.
__________________
PM for assistance
Old 17-12-2013, 14:51   #31
gac
gac has 10 points
This year's worry - the DPF
https://www.gov.uk/government/news/n...iculate-filter
If you've had it done "properly" (removing the internals only, leaving the casing, and having the software adjusted) then you might be alright. I would assume that the DPF warning light still needs to come on during initialisation of the panel, and then go out, any other behaviour would indicate a fault.
If you've had the DPF physically removed, then you're probably screwed (dodgy tester aside)...
Old 27-05-2014, 09:59   #32
gac
gac has 10 points
Quote:
Originally Posted by gac View Post
3) decatted diesels are NOT an MOT test failure. Only vehicles which require a full emissions test are eligible for the new visual check for a cat, since there's no emissions test for diesels then they can't fall into this category. And since there's no emissions test, a decat can't make you fail it. As long as you can pass the smoke test, you're fine (section 7.1, page 1)
https://www.gov.uk/government/upload...ice-1-2014.pdf
Looks like a decatted diesel is an MOT failure now; as is a diesel with no DPF where one was fitted as standard. Cats have been mandatory on all cars for a good number of years so most people on here are probably out of luck on that, with a DPF you may be able to persuade the tester that your car didn't have one depending on age.
It also doesn't say whether it's just a visual check so if you've had your DPF gutted and replaced with straight pipe inside the DPF casing then you might be alright, depends whether they do any kind of electronic check I guess and whether the de-DPF software fakes the response of a DPF in good condition or not.
Old 27-05-2014, 10:15   #33
AndrewJB
SEAT Motorsport UK
AndrewJB's Avatar
AndrewJB has 30 points
Its a visual check, best route now is to gut your DPF/CAT still leaving the casing in place.
Removal of petrol cat's has been illegal for years but we still do it.
__________________
APR Stage2 420ps Instagram: @andrewjb_e13 @seatmotorsportuk
AndrewJB is offline   Reply With Quote
Reply
Bookmarks
« Previous Thread | Next Thread »
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
(View-All Members who have read this thread : 214
/dev/null, 19shand86, 8bit, abbotsmike, aceman, adamb87, Adamricko, Al, AlexGSi2000, AndrewJB, andycupra, andyj, Ape, AshFR, Azza_, Badger, Bashiee, BEOWULF, Berg, betty_swollox, big rich, Boo, Brettyboy, britishsligean, bruceR, byerss, Canners89, CHRIIS, chris285, chrisRibiza, ChrisUK, chris_200120vt, ckyliu, cra19n, Craig Senior, Crashapollo, csd_19, Cupra TDI 150, cupra-barn, cupra.al, CupraTim, cupra_r_ick, CUPRoAr, dalegolf215, Dan Cupra R, Dan Watts, Dan1720v, DarkIce, DaveMc, dazzaboy, dedon, Deejay, dholdi, diggerbucket, DKershaw, domin8or, dougieboy, Dozer360, dw911, EB-80, EdButler, EL, Fatal_Angel, Fergal84, fr 150 boy, FRDAVE, gac, Gary29, gezmeister, googujube, great_kahn, gti dan, HarryH, Hartosh1, Hawkins94, Hobbiniho, Holdup, Ibiza125, IbizaTDI08, ijmok, Irie, James.Judd.1, JamieF, Jamiethorley, Jarre, jcs356, jc_boc, Jhouse_101, Jimski, jj06, Jokerman261, Jordanwaterhous, Karnah, kaspa_dtz, kazand, kevinking2020, Klone, Kywy, lc_allan, LEE69, leegriffiths, lesinge2k, LukeFR, luna fr, lunalupi, M30 SCK, marco cupra, marcus.l, markoos, MarkWales, marsh175tdi, MasserS, Masterkm, Mattyboy1, mc funbot, mcd90, metman9185, mickeyp88, Mike R, MikeHollis, mikemk4gti, miscreant, Miss Hamilton, mjstokes85, Mo Arif, Molehill_Mike, MPJ88, muddyboots, Muttley, Nath., ndbrgr, NeilW, niallain, NickLCR, nightflight, Nutkin, oldman, oldtimer, Paul43, Paulki, PAULTDI67, Pedestrian, phatchoonz1, PhilW, pj1985, poliq, Pr3muToS, psjunkie, ptotham, puchos, R1ch85, racingsquirrel, rae1001, ramborobert, randomage, RaviR50, RDS, Red ibiza, Redemption, Redrevis, rhumber, RicJames, rllmuk, rob - 73, Rob Kelz, rob929, RobDon, Roohul, Rorza, Russo, RY4N, seatcupra, seatcupramad23, seatturbopower, selfagg, shaw25, Shrek, skeat12, Slimy, SpawnAgain, spen, sssstew, Steely, STEVE290353, suj, super_electric, SwinDan, TazB, The Old Codger, theArchitect, Tinny, tommycx, truCido, TwoZeroAlpha, Veyron, Viking, volts, vroomtshh, VRSLOZ, WeeG, widdowd, Wilko, will.i.am, wiseman405, xavier de, yessar_kd, Yohan87, youngyWHU, yozza1987, Zaco95, zan, ZiggyEP3
Thread Tools
Display Modes Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Website © 2014 SEATCupra.net
Disclaimer: SEATCupra.net is not an official SEAT site and is not affiliated to SEAT in any way. Visit the Official SEAT Website.
SEATCupra.net are not directly responsible for information which maybe posted in this forum.
All content is viewed and used at your own risk. We do not warrant the accuracy or reliability of any of the information.
The views expressed herein are those of the individual contributors and not necessarily those of SEATCupra.net or SEAT
All trademarks and copyrights remain property of their respective owners.
