Adrian Flux
Go Back   SEAT - SEAT Forum » SEAT Model Specific Discussion Forum » Leon » Leon Mk2
Leon Mk2 For all topics relating to the Mk2 Leon
Thread Tools Rate Thread Display Modes
Old 21-11-2017, 20:18   #1
wclark1238 has 10 points
O/S rear door
Ok, 57-plate Leon. Lovely car in almost every way. Just coming up to it's 10th birthday with just over 140k miles now. I've owned it for 7 years and put 70k miles on it. Very few issues to date.
Now it has suddenly developed a major problem with the o/s rear door. It simply will not open at all. Neither from the inside or the outside. I am aware of an inherent issue with the VAG family of cars around this vintage surrounding the door lock modules - in fact I have changed 2 on this car (not the o/s rear one though). But this problem is showing different symptoms I think.
I have seen issues where the door will not open from outside immediately after unlocking (until first opened from the inside). This one simply will not all. I have verified that the cable from inside door handle to module is intact. Have even disconnected if from the handle in order to manually pull on it (in the hope that the handle wasn't quite providing sufficient movement on the module) but no luck.
Now in the situation where it is impossible to open this door. I'm guessing that the module has failed big style such that the door just won't open at all. Imagine that this will constitute an MOT fail in January.
Perhaps related. At the same time as this door gave up so the indicators stopped flashing upon unlock via key fob. When locked via fob the indicators flash but now there is no indication at this related?
So, big question. Short of using an angle-grinder is there any other way that I can get this door open? Need to do that before I can replace the module which seems like the 'proper' fix.
Any advice gratefully received.
wclark1238 is offline   Reply With Quote
Old 21-11-2017, 23:30   #2
middle aged speed freak
fozzybear's Avatar
fozzybear has 10 points
afraid you.ll need to remove door card for access to lock, you should be able to open then with handle connections.....if you have child locks on might be harder....would suggest first though take out remote batteries and this could be a problem too and easier to sort...that happened to mine....on replacing batteries all worked fine....good luck
Sent from my SM-G935F using Tapatalk
seat leon cupra 2,0tfsi running all untouched 240 bhp as standard[SIGPIC]
fozzybear is offline   Reply With Quote
« Previous Thread | Next Thread »
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
(View-All Members who have read this thread : 15
BUX FR170, CANADAHUSKY, DavieTDI, Donnyboy, Guncha, KELHAM, locky, richicupra, Rob66, Rusty2k, Skinner, slim20vt, verbal_kint, wclark1238, Wizzard
Thread Tools
Display Modes Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Website © 2014
Disclaimer: is not an official SEAT site and is not affiliated to SEAT in any way. Visit the Official SEAT Website. are not directly responsible for information which maybe posted in this forum.
All content is viewed and used at your own risk. We do not warrant the accuracy or reliability of any of the information.
The views expressed herein are those of the individual contributors and not necessarily those of or SEAT
All trademarks and copyrights remain property of their respective owners.
