Adrian Flux
Go Back   SEAT - SEAT Forum » SEAT Model Specific Discussion Forum » Leon » Leon Mk2
Leon Mk2 For all topics relating to the Mk2 Leon
Thread Tools Rate Thread Display Modes
Old 03-12-2017, 11:26   #1
Lee36 has 10 points
Pd 170 engine splutter
Hi all HELP needed
I have a 2007 seat leon tdi 170 fr the problem I have is when driving after 10mins or so when itís warmed up when accelerating hard under load in 3rd from 2000rpm it pulls fine on boost and then when it get to 3000rpm it cuts out splutters for a split second then keeps holding back on off on off in 3rd change into 4th hard on the throttle holding back cutting out not boosting properly and the same in 5th
I have had the glowPlug light and engine management light come once when I kept my foot down when it was cutting out Iíve also had it plugged into a vcds and no fault codes shown had a run on a dyno with car plugged in dpf was showing ok injectors showing ok so the garage didnít no what was wrong either the car drives fine when not on boost
Any Help would be appreciated
Lee36 is offline   Reply With Quote
Old 06-01-2018, 12:05   #2
Leistrum has 10 points
Is it limp mode you are encountering I wonder? It could be something simple like a split/perished vacuum pipe leaking causing that to kick in, its not necessarily something expensive, just needs tracing by an honest mechanic. Hope you sort it.
Leistrum is offline   Reply With Quote
« Previous Thread | Next Thread »
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
(View-All Members who have read this thread : 9
AlexUK, Asce, dMack14, FN Track Works, GordieC, kev the hat, Lee36, Leistrum, linfordfr
Thread Tools
Display Modes Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Website © 2014
Disclaimer: is not an official SEAT site and is not affiliated to SEAT in any way. Visit the Official SEAT Website. are not directly responsible for information which maybe posted in this forum.
All content is viewed and used at your own risk. We do not warrant the accuracy or reliability of any of the information.
The views expressed herein are those of the individual contributors and not necessarily those of or SEAT
All trademarks and copyrights remain property of their respective owners.
