alternator
moink10
62
Ludlow, Shropshire
Hi Everyone,
I have got an alternator problem on my car. (Cupra 240) Had a tester put on it and was told it is the alternator. Does anyone know the part number of the alternator for these cars to make sure I get the correct one? Also would it be the alternator or possibly the regulator?
Thanks in advance.
Chris
Rusty2k
710
133
What issues have you been having?
You'll probably have the 140A alternator. Check the production codes on the sticker on the boot floor for a code starting 8G. This denotes which capacity alternator is fitted. 8GU is the code for the 140A alternator.
If it's anything different to 8GU then post the code you have.
moink10
62
Ludlow, Shropshire
Thanks for the reply. Yes it does have code 8gu on the sticker.
I drove for an hour and half with no problems then left car for 3 hours and came back to start the car but the battery was dead. I jump started it and drove hour and half home. The power steering, air con and Rev counter was not working. I turned car off and it wouldn't start as battery still dead. Changed the battery for a new and it all works but put a tester on it and was saying alternator wasn't charging?
