indicators not working
adam5363
27
hampshire or notts
hi,
i have a 2005 lcr, and today my indicators decided to stop working, there is no dash indicators and no external indicators. the hazards are working and the indicators work when i lock the car. the fuse is fine. has anyone come across this problem before? and any ideas to fix?
cheers for taking the time to read
Nath.
The Gentlemans Express
Jan 1, 2006
8,620
16
EASTLEIGH, HAMPSHIRE
Sounds like the bulbs, relays,fuses and wiring are OK because they work from the hazard switch and central locking. I would be thinking your indicator stalk/switch is the problem.
Velcro
Naive Newbie :(
Jan 25, 2008
26
Edinburgh, Scotland
I've had the same issue develop on my 2005 FR TDI - did Ricky3's fix work for anyone? Anything else I should be aware of that I might need to try?
chriswales6
294
47
If the indictors are working with the hazard switch then it’s most likely the switch in the stalk. Would be worth trying contact cleaner before replacing the stalk.
The stalks are cheap enough and removing the steering wheel isn’t too bad – I even managed it. Plenty of videos on YouTube showing how to do it. Also if you don’t have cruise control an ideal time to upgrade.
masterfrodo
267
8
Was like that when I got mine. Sprayed the stalk with lubricant, and has been fine ever since
Battoussai
423
104
Portugal
Same here. Just started to blink only 3 times for left and stops for itself. Now it also does to the right side: 3 clicks and off.
Gonna spray the ******* with WD40.
chriswales6
294
47
Personally I wouldn’t go spraying it with normal WD-40, there’s a good chance or shorting out the switch.
Electrical contract cleaner would be safer, it won’t leave an oil mess over the switch.
Battoussai
423
104
Portugal
Thanks for the warning Chris.
I was wondering that last night and was going to ask the hardware store about that.
Going the safe way. ;)
Battoussai
423
104
Portugal
Sooooo... the mistery is bigger than I thought.
It isn't the stalk only afterall. The hazard light also only blink twice and stop by themselves.
So i'm guessing it should be a relay somewhere.. maybe underneath the dash near the steering wheel.
Do you guys know anything about it? Fuses are okay.
Regards.
Battoussai
423
104
Portugal
It seems the hazard light switch also have the relay built in...
Gonna have a trip to the dealer to check if they still charge an arm for this.
Regards.
