**IMPORTANT** SCN downtime from 6.30pm Tonight
ZBOYD
Looking up at the stars!
May 19, 2001
9,468
15
Cheshire
www.seatcupra.net
Were moving a lot of things around tonight, moving files over to our new shiny server.
We can't give an estimate on when it will be back online. Maybe never!! :cartman:
But if all goes to plan it shouldn't be down for too long...but things never go to plan do they. :whistle:
So if you had something you really needed to do, and your looking for that spare time to do it. Well tonight is your night, because SCN won't be around. :)
All the web services will be offline, including the email system, so if you use SCN email, make alternative arrangements.
If you need me for anything, I can be contacted by email on zboydmark[at]mac[dot]com
While we make this transition, things may not work, things may very likely go belly up. But please don't bother Martyn, he's a busy chap and he's doing us all a very big favour. If you want updates, or want to annoy someone with idle banter, email me. And I shall ignore you. ;)
Thanks Z.
If any of you have a SEATCupra.net mail addys, please empty your IMAP/POP3 mailboxes before 6.30pm as after that the contents on them will be deleted. The accounts will be recreated on the new server as and when I get time!
Brummy
Nazi Moderator-Bot
Mar 6, 2005
4,275
Moved to the DarkSide
****! this mean i might actually have to talk to the wife?!?!!?!Ok guys, go for it, im sure i can make this sacrifice for the good of a shiney new server :)
Tam
Santa in disguise :)
Feb 10, 2005
1,777
Near Reevo :)
so - is this the move to the new server, or just moving files across ready for the swap over?
I assume you are swapping files directly between the boxes rather than downloading and then re-uploading the content.
edit: DNS refresh is set to 3 hours, so if it is a swap of boxes they it won't be about much tonight due to DNS propergation.
Perhaps you can post the new IP addy - so that we can get on it sooner :D
Jonny
slightly insane monkey
Jul 5, 2005
769
South Wales
Damn... might actually have to do some work at work tonight :(
Good luck with the technical computery type stuff... way over my head! lol
Thanks for letting us know :)
WeeJase
pert
Jun 2, 2001
8,595
i'm praying for a call out.everyone in the midlands.richard the thirds and too much paper please ;)
Tam
Feb 10, 2005
1,777
Near Reevo :)
Tris, can you just confirm what IP SCN is resolving to?
> www.seatcupra.net
Server: UnKnown
Address: 192.168.100.254
Non-authoritative answer:
Address: 195.238.232.40
C:\>
C:\>tracert www.seatcupra.net
Tracing route to www.seatcupra.net [195.238.232.40]
over a maximum of 30 hops:
1 2 ms <1 ms <1 ms 192.168.100.254
2 27 ms 27 ms 25 ms gandhi-dsl1.wh.zen.net.uk [62.3.83.5]
3 32 ms 25 ms 25 ms erazmus-ge-0-0-1-3.wh.zen.net.uk [62.3.80.197]
4 34 ms 31 ms 33 ms leibniz-so-0-1-0-0.te.zen.net.uk [62.3.80.45]
5 34 ms 33 ms 42 ms lorenz-ge-0-0-0-0.te.zen.net.uk [62.3.80.42]
6 35 ms 33 ms 39 ms lonap1.enta.net [193.203.5.134]
7 33 ms 32 ms 33 ms te5-2.global-switch.core.enta.net [87.127.236.42]
8 188 ms 204 ms 54 ms te1-2.redbus-hex2.core.enta.net [87.127.236.46]
9 37 ms 36 ms 32 ms te2-3.redbus-mer3.core.enta.net [87.127.236.22]
10 46 ms 37 ms 39 ms 87-127-231-122.no-dns-yet.enta.net [87.127.231.122]
11 34 ms 33 ms 33 ms 195-238-232-40.no-dns.goscomb.net [195.238.232.40]
Trace complete.
Have highlighted things you need to fix.
Also mail.seatcupra.net is answering now as srv1.seatcupra.net so that needs looking into :)
