Does the Leon mk2 have brake wear sensors?
  • Thread starter Deleted member 74601
  • Start date
jc_boc
Missing the CUPRA R!
Jul 18, 2008
9,304
7
Desborough
I think you're mistaken. All Leons are shown having sensors on the front but not on the back. It shows 'with sensors' for all disc sizes.
My cupra doesn't have sensors either and I changed my pads recently so know this for a fact, unless it's only the newer ones which have them?
Cupra Ultimate
82
8
brake pads wear indicator
Hello i have a seat leon cupra r 2010 and recently changed my brake pads and i neither had the brake pad sensor cable. is this common that some has and some none.
Darbo
48
My 2007 pre fl fr doesn't have the sensor, just cut the wire off the pad, they still fit fine.
Muttley
Catch that diesel!
Mar 17, 2006
4,987
31
North Kent
It is a very simple sensor. There is a wire embedded in the pad which wears through as the pad wears down. When the wire wears all the way through, the sensor tells the dashboard computer 'I'm broken'. Nothing complicated. And of course, it won't tell you anything about disk wear, which is checked by measuring how thin the disks are face-to-face, not something that is easily done in-car. Not impossible, mind you, just not cheap...
I think I have pics somewhere around of these things in new and worn state. Not a lot to see, mind.
Also, worth keeping the lead from a worn pad, then if you should decide to go for aftermarket pads that don't have sensors you can just join in to out on the old lead and plug it in to keep the dash happy.
charisk123
Cyprus
OLD Post but just to confirm. I have a Leon Cupra mk2 1p 2010 177kw. IT DOES NOT have wear indicator. Just needed to cut the wire from the new pads to install it. Cheers
