Destroyed bulbs
char1s
48
Hello guys,
i have a burnt light in front of my car.
Can you help me understand what kind of bulbs we put on LEON mk2 2006?
Fog lights standard and high lights (H3, H7,H11)?
Thanks in advance!
char1s
48
Thank you very much!!
dipped beam (H7) are the normal lights and main beam (H1) are the strong high lights, right?
char1s
48
Do we have any instructions or can you explain me briefly how to safely change the H7 dipped beam lights?
Matt cla
114
Nottingham
Remove the plastic cover behind the lights...be careful with the retaining clips...remove the wired connector from the h7 bulb...release the metal clip...remove the old bulb (make note of which way the notch on the h7 bulb plate is pointing- notch should be at the top)...pop your new bulb in...reverse the process to secure it.
