Tyre pressure light removal
iDan
38
Worcester - West Midlands
I have the same issue on mine, although i think my button isnt functioning. I hold the button and it doesnt reset, but also my esp button doesnt seem to do anything either :/ any suggestions?
Hamburgalarr
104
Well I had to take the lock/unlock button apart and add some foil to the micro dome switches to fix them working. I can give instruction if this is whats needed. First take up the whole panel make sure that all the wires are correctly connected. The whole oval panel should pop up starting from closest to the gear stick.
Andy90
210
How do I get rid of the tyre pressure light on the dash
To reset it you need to hold the button with the ignition off.. then still holding turn the ignition on and wait a few seconds and it should reset.
Hope this helps
Sent from my SM-G925F using Tapatalk
