| Leon Mk1 Use this forum for Leon specific topics, for 2000-2005 models only> |
Thread Tools | Rate Thread | Display Modes |
#1 |
Water in foot wells - please help!!
Hi all,
I am looking for a solution to the leaking door seal/ water in footwell problem for my Leon mk1. With all this rain we're having in the lovely British summer there has been a puddle of water in the passenger rear footwell. There has also been water in each other footwell, but it's particularly bad on the passenger side. I have noticed that I get a foot shower every time I open one of the front doors as water is collecting in the foot plates. This seems a common problem so would welcome advice/ link to a guide wich has worked! Also, any ideas how I can easily dry the underlay underneath the carpets? Although I have used a vax machine to suck up a lot of water, there is still a squelch!! Would welcome any advice as the smell is getting worse!! Cheers all. Ed
#2 |
Senior Member
Use search facility in Leon FAQ'S theres loads in there,with some good guides
#3 |
Iv got the same issue with the passenger rear and now Everytime the weathers relatively warm my rear passenger door won't open! So glad it's finally getting sorted tomorrow. Ball ache!
#4 |
The dealer will sort it for labour of 1 hour per door or you can DIY it as suggested above.
#5 |
Stage 2 Revo'd
__________________
My Car Did you not get a manual with your Leon, or want a .pdf copy? If my post has helped you click the scales to the left and leave me some rep points. |
#6 |
Will it please stop raining!!! Have finally worked out that the water is getting in through the pollen filter - the filter itself is wet and can also see water down air intake housing.
Any ideas for a solution? Should I replace the pollen filter plastic cover etc? Have Seat updated the cover in the knowledge of the problems owners have had? Cheers.
#7 |
is the cover damaged? dont replace it if theres nothing wrong with it...its probably not seated correctly
__________________
#8 |
I've heard that's a common leaking place, either the cover is damaged or as stated the filter etc isn't placed correctly
Heard some people run a bead of silicone under the pollen filter, but there must be another way of sorting it out, otherwise you'd be creating a water trap under there |
#9 |
Newbie
Most common on Leon's is door seals mate has had two Leon's recently needing them done
#10 |
Strange because I have havent changed the pollen filter in about two years and it's only just started leaking so I am thinking the cover/ seal needs replacing. It is quite water marked.
#11 |
Well, I thought the problem was sorted...wrong!!
I am getting a lot of water underneath the carpet underlay in the passenger side front and rear footwells. The top of the underlay and carpet is dry. If it was a problem with the door seals, does the water somehow make it's way underneath the underlay? Water only collects in the front passenger door plate, you get a waterfall on opening the door. Would the front passenger door leak explain the water in the rear footwell - I.e can the water travel from the front footwell to the rear? Got towels shoved underneath the underlay to dry it up. Becoming a real pain.
#12 |
Senior Member
You really ought to take a look at the link Lee posted, but in essence all those questions can be answered with a 'yes'.
#13 | |
LCR 225
Quote:
Sounds like door seals, read the link Lee posted and get it fixed before that water turns to ice as it get's colder
__________________
LCR 225 - AmD Stage 1 - 261 bhp 271 lbs/ft Forge 007p - SFS 3" TIP - JR Cone Filter - Ferodo DS2500 pads - Cobra Cat Back - SuperPro DBM |
#14 |
Ive got the same problem...Ive ordered some butyl tape off ebay
Read and Read that Sticky thread untill you understand it,The stealers will thrape your wallet if they end up sorting it |
#15 |
Cool, thanks guys. I am going to tackle the door seal fix. Have you got a link to the butyl sealant tape? Which thickness should I get?
#16 |
I used door frame sealant (like bathroom sealant but for outdoors) from wicks!
Used it to seal the seakers that I replaced and around the bottom of the panel that leaks. Managed to stop the leak without removing the inner panel. Once the water had stopped coming in, I cut out the underlay (sound deadening) from where it goes up againt the transmission tunnel (front and rear passenger side), dried out in the airing cupboard, then put em back in Hope this helps |
#17 |
Senior Member
I give it six months to a year before you're going back in to fix the fix...
When i did my doors, they were coated in three different type of sealant, they had all failed. One roll of butyl and its not leaked since. |
#18 |
Does butyl go where the original sealant used to be?
#19 |
Stage 2 Revo'd
yes it does
__________________
#20 |
LCR 225
The link that Lee posted really explains everything you need... as the saying goes RTFM
__________________
| Bookmarks |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Display Modes | Rate This Thread |
