Ibiza Mk4 Custom Gas Bonnet Lifters/Struts - Finally Finished!
Damoegan
Sir Bob,a geordy legend..
Oct 15, 2007
8,993
Newcastle
My bracket is the same lenght as your's Paul, there just not finished yet :)
I will sort the corner out when I get some more time.
Damoegan
Oct 15, 2007
8,993
Newcastle
Making the brackets is easy for me as I have all the tools at work :D
Dont think I will have to tweak the design as Paul spent quite a bit of time on them to get them right.
Pabs
5,936
Basingstoke
Thanks Damo! :)
I don't see the point in tweaking a known (working) design myself - but go for it! Each to their own and that - my design was based on brackets that I've seen on Lexus and Skyline forums to be honest - all seem to be very similar. Really depends on your choice of strut and availability.
Pabs
5,936
Basingstoke
Yeah - it's not rocket science - just take your time and try to take everything you can into account - measure twice, cut once kinda theory!
Damoegan
Oct 15, 2007
8,993
Newcastle
:yes:
Only difference in my bracket iss that I'm using 25mm L shape stainless instead of the 30mm you used. Only because thats all I had lying around.
Pabs
5,936
Basingstoke
Should be plenty strong enough I'd think. I made a template out of tin to start with - didn't last for too long but at least it gave me the right shape/dimensions :p
Damoegan
Oct 15, 2007
8,993
Newcastle
There is more than enough strength in the bracket mate.
If your design works fine for you I am more than happy enough to use exactly the same design ;)
Pabs
5,936
Basingstoke
Yep - if I were to redo this, I'd use thinner stainless as it'd give more thread on the bonnet bracket bolts. Think you've got the right materials - but don't see the point in re-doing mine as it works fine :)
Ibiza 130 tdi
Black Magic
Jan 15, 2007
6,275
Somerset
First dibs on one of your kits Damo! You pinched the Scangauge off Chris before I got to it so I want one of these kits. :lol:
I'll pay obviously! :funk:
Damoegan
Oct 15, 2007
8,993
Newcastle
:lol:
I'll get mine sorted first then see if I can get a good sorce for the gas struts, Ash.
Damoegan
Oct 15, 2007
8,993
Newcastle
Finished fabricating my brackets now, just need to paint them. Also got some struts on the way to try :D
