Pastywagon sprint dates 2010 - Overall championship win!
RobT
Full throttle trip
Nov 30, 2001
2,548
Congleton
Aero-efficient bumper back from paint.....well nice IMO, very smooth [B)]
Rear hinge for front floor ready for floor fitting - that is a VERY tough stainless steel hinge - had to buy some special drills to drill the bleedin thing - exact shape of front edge of floor can now be finalised now the bumper is back
This weekend should see the floor and splitter fitted.
Ave it
Rob
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
Keep at it Rob. Bumper looks right - nice & tidy, but OE looking (far better than original)
How low will your splitter run?
RobT
Full throttle trip
Nov 30, 2001
2,548
Congleton
Splitter will be 120mm off the deck - minimum ground clearance is 40mm but regs also state that no part of the car should touch the ground if the tyre bursts - so for me thats 70mm
120mm comes from the position of the rear floor support - using the lower wishbone brace was an efficient way to mount it - thats 120mm off the deck
Mk1 floor will be totally flat and made from ply - if it doesn't get smashed off then Mk2 will be carbon-foam sandwich with some shape to create a low pressure zone at the front axle line
Probably from these chaps: http://www.fibre-lyte.co.uk/cf/index.html (check out their Audi S2 and TT sprint/hillclimb cars)
Note: this will not work if your car has a normal 'wet' sump as it will get in the way......mine is dry sumped and thus has much more room below the engine - the lowest point on mine is the bottom of the gearbox bellhousing
RobT
Full throttle trip
Nov 30, 2001
2,548
Congleton
I was thinking of 6mm as this has quite a few plies but is not as heavy as say 9mm - which has no more plies, just thicker plies.
Thinner and lighter the better obviously - but it needs to be 'just' strong enough
Thinner than 6mm tends to be just 3 ply and probably not strong enough.
I dont know anything about foamex....whats it like?
old 'uns
Modern Life is Rubbish...
Mar 20, 2003
1,627
walsall
used by sign companies from 2mm to 10mm comes in usual sizes up to 8' x 5'
very light, probably half to third lighter than equivalent ply?
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
foamex is light... and about as flexible (or not)
Also - if you clip it, it'll snap rather than bend what you screwed it into
They make big signs out of it etc, some are aluminium skins sandwiching foam.
RobT
Full throttle trip
Nov 30, 2001
2,548
Congleton
PVC is fine - a bit of ali tape where its near to hot things - if its as strong as 6mm ply and lighter, at the price that it is I will give it a try
although I see they also have ali composite board......I'll see what that sign place has to show me
RobT
Full throttle trip
Nov 30, 2001
2,548
Congleton
Mk1 floor and splitter design:
Cardboard template finalised - black line is bottom of bumper, red line is overall plan of bumper (i.e the widest / biggest section). Plan of bumper is relevant since rules say
"front spoilers / air dams / splitters are allowed below the level of the wheel centers up to 15cm beyond he overall plan periphery of the existing bodywork"
So I am no where near 15cm at any point.
Fitted to car:
I have taken it to the limit of the front track, 3" forward at the front/middle, and the rest is join the dots with a smooth curve.
Dead pleased - looks well mean. Transfer to foamex or ply next job.
Now its on, I can see where the venturi's are going to go for Mk2 next winter.....oh yes......
RobT
Full throttle trip
Nov 30, 2001
2,548
Congleton
well (a) it might not work and (b) it might get broken off
but its a start at least - looks a lot like stuff I have seen on other more professional racers so maybe it wont be far off and at least a bit functional
with blocking off the lower bumper opening and fog light holes, there is now quite a large 'slab' of uninterrupted airdam above the splitter (well there will be as soon as I have filled the gap between floor and bumper with PVC sheet) which will create the positive pressure zone above the splitter.....and maybe some downforce......heres hoping
and the whole lot is fastened to the chassis, so any effect might be transmitted to the wheels rather than bending the bumper
its designed based on observation of other cars and an excellent book called 'competition car aerodynamics' by Simon McBeath
also there was an excellent series of articles in Racecar Engineering about a hillclimb mini that they had in a wind tunnel and were trying bits an pieces out
http://www.carbonweezel.co.uk/testing.html
RobT
Full throttle trip
Nov 30, 2001
2,548
Congleton
talking to a mate 'in the know' today revealed that probably 9mm ply was the thing to go for as far as ply is concerned - 6mm typically only has 3 plies in it whereas 9mm has 5 plies and is much stiffer - 12mm also has 5 plies, just thicker plies, but is too heavy.
But a specialist wood place near here says they have 5-ply 6.5mm in stock.....checking it out tomorrow along with the sign production place for info on foamex board
Quick calculation this afternoon:
Assuming a density of plywood of 600kg/m3 (0.0006kg/ml)
My design in 6mm ply=3.01kg. In 9mm ply=4.52kg.
The ibiza diesel van plastic engine undertray I have been using=2.5kg
So I am not as worried as I was about the weight penalty of this exercise.
RobT
Full throttle trip
Nov 30, 2001
2,548
Congleton
I found some density figs on the net also which said 0.5-0.7 specific gravity - thats pretty much ply weight so like you say, no much in it perhaps
