MOT Failed...Emissions HELP!!!
Cupra_Rally
15
Ok, so its a rally car, I don't use it every day and don't really want to spend a fortune fixing this issue
The MOT station suggested an engine temperature sensor, or possibly Lambda sensor.....but they don't want to touch the car (which is worrying and weird as garages always want work!) so any ideas or cheap and quick fixes before I decide what to do with the car.
Has a crappy K&N copy filter on it and not too sure if its still running a cat.
has 92k on the clock too
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
If the coolant sensor or lambda needs replacing, it should be able to be picked up on a fault code scan
Will easily fail without a cat though
Cupra_Rally
15
Well, I assume the CAT is the big daft looking thing at the front of the exhaust system with a sensor off the top. It did have a nut welded to the base of it (for a shield of some sort I assume?) which got knocked off on the rally we did a couple of weeks back. This opened up two holes (where the nut was welded) so i've temporarily plugged this up which I doubt would effect the Cat itself.
Got a tame mechanic with a code reader coming round to see if he can throw up a fault code or ten!!!
