A common "fault" with the Ateca Infotainment system is the one cited as Playback Volume too low or variable between sources....
There is a menu option in the unit to control the balance between external sources. External is defined as outside the radio, SD and USB e.g. Bluetooth and Aux. The infotainment manual covers this:
The menu is on the standard unit and Plus.
