17963 P1555 Charge Pressure Upper Limit exceeded FAULT
cupra786
34
Hi had my seat leon mk1 1.8t on diagnostic yesterday since it went into limp mode, had about 11 fault codes, cleared all and today on start up eml light came back on. Plugged back on diagnostic and it gave this code:
'17963 P1555 Charge Pressure Upper Limit exceeded'
Id say its to with a faulty n75 valve? but if anyone could explain what exactly this code and the solution to it is it would be appreciated.
Cupra786
cupra786
34
Iv already changed the n75 valve once due to the old one being knackered. Bought a new one and for the first week or so ot was fine. would you say its a faulty n75 as i can still claim warranty on it
RyanWaters
7
Ive just had the same code pop up! Cars gone into limp mode. I need help
Sent from my SM-G930F using Tapatalk
verbal_kint
639
31
North West Kent
Courtesy of Ross Tech
17963/P1555 - Boost Pressure Control: Upper Limit Exceeded
Possible Symptoms
Reduced power output
Limp mode
Possible Causes
Boost Pressure too High
Hoses/Pipes incorrect connected, disconnected, blocked or leaking
Charger Pressure Control defective
VNT (variable nozzle turbo): nozzles stuck
Solenoid Valve for Boost Pressure Control (N75) defective
Possible Solutions
Check Hoses/Pipes to/between Components
Check Solenoid Valve for Boost Pressure Control (N75)
Check / Clean / Replace Charge Pressure Control
Check / Clean mechanism for variable nozzles
If you're doing the work yourself you might be lucky and find a vacuum pipe split somewhere.
