Passenger door not opening
Shepo08
41
Surrey
As title says really, I have been trying for days now but I am getting no luck, the front passenger door will not open from the outside or inside, does any one have any ideas what this could be please ? I have took the inside upper panel off and sprayed some wd40 on/in the mechanism but still no luck!! [:@]:cry:
Jimbobcook
6,149
2,531
Thus may sound silly but my brothers ibiza front door wouldn't open and I found somewhere on this forum that if you push just above the door handle like your trying to slide the door up then open the door whilst pushing in, it's like the clasp holding the door locked doesn't quite make it over the latch.
Maybe worth a try..
Obviously don't do it too hard otherwise you may be calling for a dint repair as well...
Simon
Madman0405
25
Eastbourne
I had the same issue and tried many different methods including removing locking mechanism and cleaning and still didn't work. I ended up changing the whole mechanism for another one from eBay and hey presto door now opens.
It is a bit of a faf as you have to remove the whole door card for the front doors to gain access.
Good luck
