Chris Knott
Go Back   SEAT Cupra.net - SEAT Forum » SEAT Model Specific Discussion Forum includes Members Projects » Leon » Leon Mk2
Leon Mk2 For all topics relating to the Mk2 Leon
Reply
Thread Tools Rate Thread Display Modes
Old 14-10-2017, 22:44   #1
SB Cupra
Red liner
SB Cupra's Avatar
SB Cupra has 10 points
Rear door not unlocking of key
Anyone else had a issue with door not unlocking with key? It will open and close fine once opened from inside car but not on first unlock
SB Cupra is offline   Reply With Quote
Old 16-10-2017, 00:29   #2
slim20vt
Senior Member
slim20vt's Avatar
slim20vt has 10 points
Yep it’s a common issue,door lock is on its way out.
New one is around £130 /breakers around £40. 30min job to fit but door card needs to come off..
__________________
Seat Leon Cupra K1
Revo Stage 1 map,Revo powder coated intake,Airtec FMIC,boostgauge vent install 315bhp+
slim20vt is offline   Reply With Quote
Old 16-10-2017, 00:42   #3
SB Cupra
Red liner
SB Cupra's Avatar
Would it need coding or is it just a straight swap?
Old 16-10-2017, 22:36   #4
slim20vt
Senior Member
slim20vt's Avatar
Straight swap chap,just need the right torx set
__________________
Seat Leon Cupra K1
Old 16-10-2017, 22:48   #5
SB Cupra
Red liner
SB Cupra's Avatar
Ok thanks pal
Old 17-10-2017, 19:46   #6
adon30
adon30 has 10 points
Try the wd40 trick. Search YouTube for it if you don't want to completely remove the lock and panel.
I removed the lock and opened it slightly before spraying inside. Didn't work straight away but a few hours later it started working. Hasn't worked for months before that.
Dealer wanted £130 for a lock.
To completely remove the door panel/ lock you need a long Tx30 and a spline/square for removing the lock.
Rears are a lot easier than fronts.
Assuming it's rear passenger like everyone else has...
adon30 is offline   Reply With Quote
Old 17-10-2017, 19:47   #7
SB Cupra
Red liner
SB Cupra's Avatar
Haha I will try that hopefully will do the trick, I'll try this weekend and let you know how it goes
Old 17-10-2017, 19:55   #8
adon30
The rears been down on mine for months. Usually wouldn't open from outside then from inside intermittently.
At which point I put the key in the drivers lock and since then over the coming weeks the passenger front stopped working and could only open the drivers using the key. Spent the weekend doing wd40 on them all and resetting the lock pulls on the front. All working at present although may still buy a replacement rear as not sure how long it'll last.
Old 17-10-2017, 20:21   #9
Rusty2k
Rusty2k has 10 points
I've had both of my rears go, though a couple of years apart. Replaced both with used items from eBay and they've been fine since.
With the rears you don't need to take the door card off. You just need to remove the trim panel from the door card. This provides enough room to remove the lock.
Rusty2k is offline   Reply With Quote
Old 17-10-2017, 21:37   #10
SB Cupra
Red liner
SB Cupra's Avatar
Thanks for info, by the sounds of it it's a common problem, it's my rear right what doesn't work, I traveled 300 miles for my k1 but didn't think to check rear doors, I soon realised when tried to put car seat in and wouldn't unlock with key, it's a bit annoying as having instant access to all doors by remote is essential but hopefully be fixed this weekend 🤞🏽
Old 18-10-2017, 08:34   #11
redrob0108
redrob0108's Avatar
redrob0108 has 10 points
The WD40 trick worked a treat for me but was on front door
https://www.youtube.com/watch?v=qWYkjlcR1Ws
redrob0108 is offline   Reply With Quote
Old 10-02-2018, 14:49   #12
Jimbobcook
and karma is restored...
Jimbobcook's Avatar
Jimbobcook has 10 points
Hello buddy, I seem to have this issue for 3 of my doors, are yours still functioning after you sorted yours?
Also did you normal wd40? Did you tape it up afterwards?
Currently Driving - SEAT Leon Mk2 Cupra R 2010
Previous Car - SEAT Leon Mk2 FR 2007
Jimbobcook is offline   Reply With Quote
Old 10-02-2018, 14:53   #13
redrob0108
redrob0108's Avatar
Mine still working fine and I put bit of blutac over hole so I can top up anytime
Old 10-02-2018, 14:55   #14
Jimbobcook
Jimbobcook's Avatar
Legend, cheers for the reply.
Looks like I'm drilling 3 motors tomorrow then haha any pointers that's not in that video?
Old 10-02-2018, 14:57   #15
redrob0108
redrob0108's Avatar
I've only done front doors and video was good no changes
Old 10-02-2018, 15:02   #16
Jimbobcook
Jimbobcook's Avatar
Thank you for your help.
Have a good weekend!
Old 10-02-2018, 15:08   #17
redrob0108
redrob0108's Avatar
Hope all goes well
Old 11-02-2018, 16:20   #18
Jimbobcook
Jimbobcook's Avatar
Hope all goes well
Well tried the front passenger door today, just going to give it some time as that door didn't work since I got the car.
Hopefully win win, the door still locks so that's a start haha
Old 12-02-2018, 11:34   #19
Jimbobcook
Jimbobcook's Avatar
Update.
It seems to be working a treat, happy days
Reply
Bookmarks
« Previous Thread | Next Thread »
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
(View-All Members who have read this thread : 35
adon30, Ape_, Asce, bete noir, BOBisREADY, BUX FR170, Chippyabs, Ciosmi, dean_ollie, Guncha, Jaruba, Jay sx, Jimbobcook, Jurebv, k1_Joynesy, kazand, KELHAM, leannaf2721, locky, Mdonno, Number12, Pdog, redrob0108, richicupra, RnPnJ, Rusty2k, Scby555, SilvaBlack, slim20vt, Speed-FReek, Storey1984, T0DDY, Tomer 20VT, wclark1238, Wizzard
Thread Tools
Display Modes Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Website © 2014 SEATCupra.net
Disclaimer: SEATCupra.net is not an official SEAT site and is not affiliated to SEAT in any way. Visit the Official SEAT Website.
SEATCupra.net are not directly responsible for information which maybe posted in this forum.
All content is viewed and used at your own risk. We do not warrant the accuracy or reliability of any of the information.
The views expressed herein are those of the individual contributors and not necessarily those of SEATCupra.net or SEAT
All trademarks and copyrights remain property of their respective owners.
