Chris Knott
Go Back   SEAT Cupra.net - SEAT Forum » SEAT Model Specific Discussion Forum includes Members Projects » Leon » Leon Mk2
Leon Mk2 For all topics relating to the Mk2 Leon
Reply
Thread Tools Rating: Thread Rating: 23 votes, 5.00 average. Display Modes
Old 10-09-2008, 02:08   #61
Allan Andersen
Allan Andersen has 10 points
cupra
Ok well i have read the hole tread, and now for the 100000 dollar question.
i have leon cupra from 2 week 2008.
it has complete miltek exhaust
forge twin ic ad remapped.
I ave experienced fuelcuts at topspeed and topspeed only, the engine lamp start flashing, for around 30 sek and after this everything is normalm so what will be the right solution for me, change fuelpump, and to which one? (where to buy)
injectors, could that be another issue?
look forward to the answer, so i can run with no worris.
the car is running 298bhp at the time.
it has not been remapped after mounting ic and exhaust, but the problem was there before, so it cant be that.
Allan Andersen is offline   Reply With Quote
Old 10-09-2008, 12:08   #62
chrisboyle999
MFD3 for sale, inbox me.
chrisboyle999's Avatar
chrisboyle999 has 10 points
Quote:
99p answer.
as i understand it, the fuel cut issue happens mid range, not top end.
the volume of fuel is engine rpm dependant and the fuel pumped at high rpms is sufficient whereas at mid range it is not.
if your issue is at 'top speed' (high rpms), then yours may be a different problem.
chrisboyle999 is offline   Reply With Quote
Old 10-09-2008, 13:02   #63
GIAC
Posts: n/a
Sounds like its the pump to me.
My car, same model, same problem on top end. I noticed that it happens through the gears aswell but only if i catch the limiter. The car doesnt cut out completely, just cuts back on power for a while as the management light flashes and then good to go.
If i were to swicht the car to its stock file, NPs, hammer it, hold it flat out, catch the limiter, NOTHING
Old 10-09-2008, 19:40   #64
jon-tfsi
jon-tfsi has 10 points
My car has the same symptoms and im assuming its the fuelling although the management light does not flash on mine. It didnt do this before i had it remapped and no fault codes came up when my local dealer plugged in the diagnostics.
I have ordered a new cam follower so will be taking the pump out at the weekend for inspection of the follower and cam.
My car is the TFSI Sport model so presumably the demands for fuel would be lower than with a remapped CUPRA ???
The engine has done 54k, 51 of which was done totally standard. Could it be wear in the pump itself and it no longer likes operating at the higher rpm,s?
jon-tfsi is offline   Reply With Quote
Old 10-09-2008, 20:05   #65
ibizacupra
Jack-RIP my little Friend
ibizacupra's Avatar
ibizacupra has 50 points
logged block 230?
__________________
BADGER 5 LTD: NEW WebShop >> www.badger5.biz
RACE PROVEN PRODUCTS & HONEST ADVICE:
Contact:01453 822880
Bespoke Big Turbo conversions,AEM WMI,Forge,Ferodo,AP Racing Brakes,Custom Mapping,REVO,H&R,Eibach,KW,Koni,Milltek,Jetex,Vibratechnik,Compomotive,DTA,Jenvey,Brembo brake kits,EBC,Koni,Neuspeed, and much much more...
http://www.badger5.co.uk
email me at:bill@badger5.co.uk
ibizacupra is offline   Reply With Quote
Old 10-09-2008, 20:07   #66
Al
Senior Member
Al has 30 points
Do you have access to VAGCOM? If so, monitor channel 230 and check for the variance between fuel pressure requirement and fuel pressure actual. The difference is the shortfall in fuel and if the actual fuel pressure is too low vs what is required, boost is dropped, and if it drops too far, thats where the ECU cuts the engine to preserve it.
Al is offline   Reply With Quote
Old 12-09-2008, 21:37   #67
Chris_Cupra
Chris_Cupra's Avatar
Chris_Cupra has 10 points
Fuelcuts as a result of inefficiency of the stock high-pressure fuel pump (HPFP) to cope with the increased demands in the peak boost (mid-range revs) is a different issue compared to engine stuttering as a result of misfires at higher revs...!!! There has been an issue with misfires in 2008 Cupras and in general the K04 turbo TFSI engines (also in the Audis S3/TTS)...
I think you should get someone (or yourself if you can) log your car with vag-com for misfires... I guess this is the problem as you're saying that the check engine light flashes at high revs...!!! Hope this will help !
Chris_Cupra is offline   Reply With Quote
Old 15-09-2008, 17:35   #68
kezFR07
now with ko4 power
kezFR07 has 10 points
iv had mine inspected today at jbs and the cam follower and camshaft are both worn down it cut out when the map was on. the maps off now. does anyone know if seat will replace the cam and shaft under warranty as its a weak part? has anyone had one replaced?
kezFR07 is offline   Reply With Quote
Old 25-10-2008, 23:56   #69
Smiler-MK2
Fear The Inferi
Smiler-MK2 has 10 points
How to change your cam follower DIY
http://forums.fourtitude.com/zerothr...3750088&page=1
Smiler-MK2 is offline   Reply With Quote
Old 01-12-2008, 00:09   #70
RodneyA
FR crazy
RodneyA's Avatar
RodneyA has 10 points
this is a bit late i realise as i only joined the forum recently.
now my thoughts have been to get a remap although i don't wish to sit with the reliability issue after long term use.
SEAT has left our country due to South Africa only being able to sell 2600 SEATs since its launch in 2006.
although VW will honour all the warranty and service/maintenance plans till the end of its term.
i realise the TFSi engine is basically part of the VAG Group, my issue after reading the complete thread...does this issue affect cars that choose to remain stock standard?!...as i plan to keep my car for as long as it takes.
don't wish to sit with the problem one day and then VW waves bye bye to me...it'd break me.
thanx,
RodneyA
RodneyA is offline   Reply With Quote
Old 01-12-2008, 09:26   #71
Al
Senior Member
Al has 30 points
Quote:
The wear issue is caused by the fuel pump being driven off the camshaft. This happens if the car is stock just as it would when it is tuned.
Old 05-01-2009, 12:47   #72
CupraSport
CupraSport has 10 points
Car getting it's 20k service at the weekend getting them the check the fuel Pump will let you know what happens. I'll try and post picies
Ok the cam follower was fine took pic's will add them later. Thank you David Cooks for checking it for me
__________________
Mike
07 Leon Cupra it's yellow baby
Toledo 2.0 ltr Tdi sport gone but not forgotten (currently for sale)
Silver 8v Cuprasport departed in a salvage yard near you apparently
CupraSport is offline   Reply With Quote
Old 02-02-2009, 23:21   #73
CupraSport
Pic of my cam follower now attached
You can see it has had some wear but it's still black and in good condition
__________________
Mike
Old 02-02-2009, 23:38   #74
ZBOYD
Looking up at the stars!
ZBOYD's Avatar
ZBOYD has 50 points
Yer not too bad, but I wouldn't personally leave it too long to get it changed, the teflon coating is wearing and going off the image alone you can see the metal shining through so I think it would be wise to swap it out in the next 10000 miles or sooner.
For what is a £23 part thereabouts, it's worth seriously considering.
Mine's not done 10000 miles yet, so it's interesting to see.
__________________
Mark
email: zboyd@seatcupra.net url: www.seatcupra.net/
The occasional use of a Skoda Yeti SE 1.2TSI DSG
ZBOYD is offline   Reply With Quote
Old 03-02-2009, 10:51   #75
CupraSport
You are right about the part price not expensive, I don't think the light is helping much, was sure I could not see the metal on it... Mmmm got me thinking. I compared it against the Audi US pics as well when it was in there and it looked fine. Prob change it at 30k or in 12 months or on my brake fluid swap in May / June as warranty will be starting to run out then cannot have that disintegrating in my engine when I have to pay for it as that would be an expensive bill. So glad they have redesigned the engine and taken this flaw out.
Would be good if others could have there checked at service time and post up pictures, would give a better feel off how they are lasting, it cannot be completely random.
Mine is an MY08 chassis Cupra apparently according to the chassis number
__________________
Mike
Old 03-02-2009, 12:54   #76
ZBOYD
ZBOYD's Avatar
ZBOYD has 50 points
Mine is MY08 too. It may just be the angle of your piccy, as long as the teflon coating is still in good condition then I doubt there is much to be concerned about. But it's good that we are being proactive and checking it.
I take it they checked the camshaft lobe while they had the pump off too, remember its two surfaces that are rubbing against one another, the piston face and the cam lobe.
__________________
Mark
Old 03-02-2009, 16:00   #77
Rampage
Trainee Northener
Rampage has 10 points
Is this something you can take-apart to check yourself without voiding the warrantee?
Rampage is offline   Reply With Quote
Old 03-02-2009, 16:08   #78
ste-lfc
ste-lfc's Avatar
ste-lfc has 10 points
I got mine checked yesterday during 2 yr service,dealer said it looked fine, 12250 miles,i will check it every service...they took some pics for me i will try and get them up....
__________________
07 luna cupra black wheels|sachs clutch kit|bilstein b8 shocks|eibach sportlines|cup splitter|stg 1 remap...gone but never forgotten
now driving-330d m sport with all the toys
ste-lfc is offline   Reply With Quote
Old 03-02-2009, 18:27   #79
kezFR07
now with ko4 power
did the dealers check it for free mate? or put extra on the cost of the service? i need mine checking to get it done under warranty
Old 03-02-2009, 18:48   #80
YIN
Leon cupra Mk2
YIN's Avatar
YIN has 10 points
Quote:
Have a read
http://forums.vwvortex.com/zerothread?id=3750088
YIN is offline   Reply With Quote
Reply
Bookmarks
« Previous Thread | Next Thread »
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
(View-All Members who have read this thread : 1689
-pseudonymous-, -SlicK, -UzY-, /dev/null, 1.8T, 10man, 140SPORT, 14k, 1Toomanycars, 2011LeonFR, 20vtB0b, 20vturbocupra, 22john, 22ssingh, 2die4, 2G, 3pointturn, 4/4 dirty dervs, 5imonharri5, 6moe66, 6th.replicant, 747_727, 8@nO$, 8bit, A.smith-Cupra, Aaron*, aaronb84, abbotsmike, abdullahb85, ablackcupra, Abs2788, acespizee, Adam's Cupra, adam1811, adam23, Adam83, adamb87, Adamm, AdamRoutley, adm013, Adman77, adrianofrcarlos, adulka, adz83, ADzABOUT, Aidso101, ajs14, aka, akg, akz, Al, Al3ks, alans, alesi27, alexj124, AlexK1, alexmsi, alexpb, alextt93, alijay, alionka, Ali_Hayes, Allan Andersen, AllanCupra, Allan_84, allbutt55, allisonbreed, Allsebrook2006, Almandino, Alnitak, alog4287, Alsh, Alunakis, alwaysinfront, alx_chung, Alzak, Amir_dan, ammar3689, andieleon, andpen, Andrei_Nick, AndrewJB, Andrewski, andrew_leon, Andy ap, Andy Bird, andy fr180, Andy McCombe, Andy,s.scfr184, andychef1234, andycupra, Andydavy, Andyg1978, AndyG_TSi, AndyH38, andymac123, andypower, andyspencer, andytaylor1980, Andy_FR, andy_lux, angy, anthony37, AnthonyDi, antipesto93, AntneeUK, Aok82, Ape, apsol, ArcticCupra, ares, ARi01, arsenalmorris, Art0ir, ARTTAY10, asasprey, Asce, ash101, ash3435, Ash5314, ashbash, ashthomas88, asifk, asilaydying1234, asquith_4, asthpsw, avendit, AwesomeAl, AwesomeHassan, AzzA Dobson24, B1rdy, b21playa, B5NGV, Babyface, Bacon, BagFullOfLeon, BAGZ, Baileyt, Bakes100, Balddee2, balls deep, bane_punk, banksy21, barnybullet, Barry-Lee, BarryB, batman1990, batwing, BazTango'd, bbob, Bbqforce10, Bedlam, beeko85, BeezerDiesel, belfastchris45, Ben CTR, Ben P, ben20VT, Ben750, ben@amdessex, benhampshire, benito, beniz, Benjic2, benrobbo, BEOWULF, bete noir, beterthanlife, betts, betty_swollox, BHP Addict, bibsen, BIBULENT, Big Dunc, big eck, Big Lee M, Big-Pete, bigbadjay, Bignod00, Big_Mikey_G, BIG_Y, Biker, Bikerz, bil44, billh, billyhas, birchy2010, BirdDog, bisto48, bjh_101, bjornatron, bkingb, BlackCupraa, BLACKNIGHT, Blade, Blades, blade_jo, Blaine, bloody_typical, bmb779, bobak, Bobanegra, bobphatboyphat, boditza, Bogwoppit, bondbill2k2, Bonzy1800, borderboy, borisvanhalen, Botor, boxster, Bozlin, BPrudence, bqd, Br!dges, BraddersThe3rd, brad_barker12, breedish, Breezapom, Bregt14, Bretty, Brinkz, bristolsparks, britishsligean, BrokenBones, Bronk, Browesy, BrownFox, Bruce GT3, Bruce-m, brucey1, BStones, bubba, bubbles1, Bully007, BumbleJC, burrell, Button, BUX FR170, Buzz123, bws, C.B, C3PRA, Cabbage, cadman2k, CalBrad420, calvR, campbell_p30, carlamos, carlt69, Carlymart, carl_ep91, carpboy, CatB1, cav, cawsey18, cdmalpass, cg11bby, cgrillo, Chambers_CUPRA, Chan_P1_TDi_FR, charisk123, charlesz1066, charlie boy, CharlieRCupes, Chemical Al, Chester, ChesterRover, cheungy, chilli, chopper-lew, chorlton, chr1sd, Chris B, Chris Bartram, chris1788, chris285, chrisb2284, chrisboyle999, ChrisCurzon, chrisf1903, ChrisGTL, chrisjgill, chrisjm29, chrispyvrs, ChrisSutherland, chrisw_mk2cupra, Chris_a_73, Chris_Cupra, chris_foci, chungster, cila555, Ciosmi, CJcupra, CJRamze, ckempo, Clark10, claroz, class2ldn, classic84, claudefrog, Clazzer, Clossie, CNleoncupra, cocadave, Colin C, Colledge87, colsy, ConnorWatt, coolantrs, Copey, corradophil, CoScolai, cossiedave, CovCupra, coxxic, cpcpeter, Crafoo, Craig D, Craig FR, Craig01988, craigboca, craigib76, craigy86, Crashapollo, crigisback, Crize, Crono, csd_19, CTID, cuky, Cupra Chris, cupra fan, Cupra Jim, Cupra Kev, CUPRA QRO, Cupra R, Cupra R Matt, Cupra Ross, cupra tda2, cupra yk1, cupra-ads, cupra-db, cupra-esx, Cupra-jay, cupra-tfsi, cupra.al, cupra123, cupra14, cupra2008, cupra2424, cupra29200, cupradan, CupraEst, CupraGTI16V, cuprakemp, Cupraken, cupralite, cupramillo, cupramk2, Cupranation, cupraNW, CupraR1, cuprar265, Cuprarob112, cuprarstu, CupraSport, cuprastoffs, CupraString, CupraTOC, CupraVAG, cupra_ahhh, Cupra_G, Cupra_Jay95, cupra_r_ick, Cupra_Wayne, CyborgCupraJQ, C_ED_99, D...B..., d11nyd, D8MNS, dafe01, Daffy, dainott2105, Dale_tem, Damon_, DaMouse, Dan FR, Dan.Payne, Dan07FR, Dan1720v, DandB, Dandle, DanGB, Dangerous Dave, DanH, Daniel H, daniel_18, danneth, dannocuprar, danny mk3 cupra, Danny-, danny20vt, Danny@INA, DannyC87, dannychapman10, Danny_FR, danpalmer, DansFR, Dan_90, Dan_FR_DSG, Dao, Darbo, Dario, darkhorse, darren2611, Darth Revan, Datapro0, dav, Dave 20vT, Dave 77, dave mac, dave.richmond, dave1814, DaveD, davej_anderson, Davescooby, DaveysFR, dave_ph, david.swanson, davo, davyboy, daz, Daz P, Daz031178, daz20vt, Daza, DAZFR72, dazjb69, DBD19, dbscupra, DCNI, ddc, deamer44, DeanJ, deanogee7, dearly beloved, Dearnie, Dec66mk2fr, Deebo, deebow, deepdragon, degzy, delboyuk2005uk, densil, Deplunk, DerbyForget, derelyth, dez22, dezthestig, dfort1uk2, dicky FR, diesel01uk, Diesel81, dieselface, DIFT, diggerbucket, DigiGuru, dijas, din_Shaz, Dirt Junkie, DJ-LIAMC, dj.bang, djscorch, DJ_Steve, DMackie, dmkay_80, dnahacker, doctor rage, dohc52uk, Donnyboy, dooresy, Dopedpanda, Dorny, Double B, Doug, Doughmac, dougiekillen, douglas10, Dr-LCR, drewFR, drizzlefizzzax, druddle, Dubslag, Dude, Dudemeister, dukebox9reg, duncinascoob, dustyivan86, dvinell, ecklad, eddiel34, Edgarasv, edgeog, edtheduck, effess, El Dingo, el leone, elfigo, Elliman98, ellsmacd, Emm, Emocion77, emsquared, EndlessNameless, EoinM, epts2008, Eric87, Eriedor, Erijaso, erminio, eta76, Evan@APR, evo2345, Evsi, ex888, fa11ows, Fahid82, Faisal, faisal1203, falzotti, FarisBB, fat andy, Fatal_Angel, fATCH, fellowsuk, Ferryman, fike, finchyboy....K1, fireblade929, Firefox75, firestorm, Fl@pper, FlameRevenge, Fluff, Foo56, Fordy_FR, ForgeMotorsport, fossie, fozzybear, FR Ritchie, FR+TDI, FR-LUMPIT, FR200, fr550, FrChappers, FReakingSeat, Frederic-cupra, freekie, Freewheelin', frodofast, frost87, fr_craig, FR_Kris, FSiLeonMike, fyfe9, G.P, G19RJS, G4reth, G5RBY, g60stu, Gabster, gac, GainfulShrimp, gammar, Gandi67, Gar3th, Gareth 265 R, gareth86, garetha1980, Gareth_1.8T, Gary S, Gary@Cookies, Gaz-04, Gaz20VT, gazbcupra, Gazbo22, Gazhill81, GazM, gazprice79, gazz01, Gazza_24, Geordie2001, Geordie_Paul, GeorgeChios, Georgel, gepsoh, Gex, gfarm101, GhostMjr, ghosty, GhulamAfzal11, Ghunter, gillygilbert, Ginner, giveadinet, Gixxer3000, Glovepup, GMInsite, Gnollins, goldie87, Golf-GTI-MK1, googies, Goot, Gracey, Graf1x, GrahamFR, Gray & Kirsty, GrayT, Grbeduff, greenocktriple, gregy_reynolds, GREG_R84, GREY 225, greyfloppyhat, GS16LRHP, gsdude, GtSport, gulzar, Guncha, gunnergibson, gunsdontkillppl, Gw19, H & H 2.3, habboub, Haddock, Hairy, Hamburgalarr, hamlyn, hamps_w, hara, Harris., harry171, Hartosh1, Has, has22fas, HasF, Havok316, Hawkers, Hawkins, hawtin1584, hayesey, hazzagrant, Hb69, Head on Fire, Healyrae, hedgehog-harvey, heggie, heliliam, hellowed, herbie147, Hilla LCR, hilly81, Hobbiniho, HotHatchSteve, HTarim, HuckingFell, Hud, Hudson, hulf_fr, hungabunga, hunggar, Hurdy, huvo, Hybrid, Hydrovert, IanG, Ibia FR 1.8T, IbizaAlex, ibizacupra, ibizajamie, IbizaTDI08, ibiza_1.4tdi, icemancupra, icestorm81, Ictoanuk, iDan, idjbell, Igor23, INA, Indy, indyr, InfernalBadger, Invicta, Invincible, Invisible, invisiblekid, IOMMAN, irf, itsmefishy, J0N, J0n3, J3PPY, J400uk, J500ANT, J888MYY, J@mes, jaba101, Jacey Boy, jackett, jackoni, Jairm88, jake, jakesbrakes, Jakeyz92, jam1, jamandspoon81, james.milroy, james12, JAMESYBOY-08, James_3, jamfool, JAMI3, Jamie55, JamieF, jamiegwillym, Jamiemerrilees1, Jamiethorley, Jamiex17, Jamie_k1, Jamie_Ldn, JamMar360, JamMonkey, Jammy78, Jarre, Jaruba, Javirero, Jay, jay-bob 25, jay87, JayCee, jaykicksass, Jaynemc, Jayz, jazza fr, JB21, JC, jcp, jc_boc, jds, Jedimaster65, jeff030379, jeffg, Jelly Baby, jendy, jez283, jezyg, jgy6000, jh1, Jhouse_101, Jhunter_83, Jimbobcook, jimboy, jimjamsco, jj06, JK1, JKM, jlecour, jma8299, jmc1976, jmcvicar, JMP, Jodrell, Joe M, joely, Joens, joestella28, Joe_3490, John-Cupra_TDI, john.s, johnbev, johnny_reyno, Johnstone, jon-tfsi, jonathanp, Jonezyfr, jonjay, Jonny, jonny1978, jonnyash, JonnyBCK, JonnyF, Jonnyruddick, jonovan82, JoonasFr, joostdeblok, Jordan359, Jordanlivi1, jordanogrady, jordyboy004, jorgii, Josh, JoshCupraR, Joshh, Joshkcupra, JoshRedCupra, joshwill, JP6, jpclarke, jreedy, jurand, Justa, justsean, Jwk, JWLeeson, J_280, K.S.D, K1 SNY, K1ROSEDAM, K1Shane, k1_cupra, k1_Joynesy, k1_tom, KarenJ, Karl db, Karl w, Kaza, kazand, KDV, KebabWarrior81, Keith Wood, Keithio, KELHAM, kenny_fr, Kenshi0001, kerem129, KernowFR, Kev Hall2, Kev07, Kevgrady, kevin1989, kevlaa, kevscupra, Kewster83, kezFR07, khaos, kidinspace, killbot, kiminauta3000, King of comedy, kingy89, kirkyboy3, Kiukas, Kneller, knight, Knight_Rider, knoted, koala5, kohmikey, koush, Kr1s0121, kr42yxx, krik, kroni, kryptik, kw1984, kwstasp, Kye69, kyleb123, KYLEB88, kylemartin93, Kylep943, L.R.C., L@on, Laidbackdaddy, lajohnz, Lally, LasseO, Lavery, Lcampbell_91, LCR User, lcr.kenny, LCR350, lcrb, lcrboy, LC_15, lc_allan, Lee M, Lee2.0tfsi, lee3011, lee3272, leeapole, leecupra240, leedscupra_r, leegriffiths, leemclellan, Leeoncupra, Legojon, Leigh15, lelilo, lemmentalja, Lentäjä, Leodis, leon cupra r, leon petrolhead, leon.il, Leon1600s, leon263, LeonCR, LeonDK, LeonFR07DSG, LeonFRDave, LeonFRMK1, LeonFRNik, LeonJamie, leonmk2cupra, leontdi130, leonvt2001, leon_in_uk, leon_lib, Leon_MHX, lesinge2k, leviathan18, LewisW, lexyy, lips10, Lisacupra, littlefella, liver-red, locky, Lodey23, lodge, lofer, lofty987, Londy, LONZO, lordgibbness, LOU ROB, lsg60, lsm, LucaFR86, lucifer666, Lucio Bravo, lugsy, luke101, lukecupra2001, LukeFR, lukey K1, Lukeyx, Lukeyy, Luke_buk, luke_h, lupocharged, m.001, M1C VX, M1KEH, m3eater, M477YEO, m4rtin, M600RKC, M6TT F, M7R, Mac, mach4, mackgold, Mad Jock, MadFaz, madfx, Madman0405, Madmile, magicmcfc, mainaman, maj81, makkakm, malaroo978, MalcB, Maln, Mandu, manhota, Manny, Marc87, marcosport, marcus.l, Marino, marjanot, mark-cupra, MarkE, markgb, Markkoni, markl, markm49uk, markmeus, markojay, marks_leon, mark_eisner, marraa, Marshall, martas4676, martin j., Martin P, martybelfasTfsi, martycupratdi, martziniuk, maryius, Mashburn, massouille, Masterkm, Matchman50, MathiasVN, matt-tsi, matt09, MATTCR, matthab, Matthewsarg, matty1000kk, Matty1986, matty_glanza, matt_s, matylad, mc funbot, mccracd, McZan, mdmay, Mdonno, mds1256, Memme112, metman9185, Mick288, micky 32, mihai_0507, Mike H, MIKE THOMPSON, mike000, mike0105, mike89, mikee66, mikef92, mikeymike, Mikey_P8, mike_allison, Mike_Leon, Millbo, miller 666, mini_racer, minority, miscreant, Misko, miss_cupraR, Mitchy, MitraShark, MJ, mk2 cupra r, mk4 cupra, mk4dub, MM95, mnkiboy, moggy, moggytom, mogsy, Moley RUFC, monk3y303, monkeynuts, monkgti, morini, moschopz, mosso, mouse1989, Mozza82, mozzer260185, Mr Bigglesworth, Mr Cellotape, Mr Scubatank, Mr&MrsS, MrDurst, MrFwibble, mrkev, mrowell, MrStevo, MrT, mrvavavoom, msz, mty12345, MUFFIN, muks11, Murdered LCR, murph81, mwat5on, MWG, MyCarSpares, mYGeL, n0ble, Nads123, nam, NAS23, Nath-leon, Nath., nath86, nathan., Nautilus, nc30rider, nealy578, Neel-Cupra, neeleyveeley, Nef, Neil82, NeilC, NeilMcK, NeilW, neil_1821, neil_f225, neo265, neon1, NewShoes, Newstarter, nibbles, Nick, nick-fr, Nick666, nickbrown_500, NickCupraR, NickLCR, NickP, NickShaw, Nick_TDi, NigelCupra, nikolai, nils 6l, NinjaPirateUK, Nobber, nog, noktoto, northern monkey, northernmonkey, Number12, Nutkin, NVM, NWhiteley, Octane2097, old yella, OLDLACE, OldManPooley, OLDOILER, OldSpeckledBen, olethalb, OliCupra, olip74, olitaylor07, Oliveracc, Olivermalyn, Osc, oscar-cupra, oswal, OU0Cupra, outstandingwork, OvniAl, owen lcr, ozaudio, ozzymyster, p11lkw, P13ULC, pagey198, Pander, Par, Pat15312, Paul B2010, Paul Cupra R, Paul197, paul7619, paulfs, paulgtir, PaulieB, Paulki, PaulLFR, paulplom, Paulr89, paulw2427, Paul_W, paul_zx6r, pavel1771, PBrowny86, Pedestrian, pedxxx, Penguin, penny58k1, Peppermuncher, Petecog79, Peter 87, peter3hg, PeterS, petrolhead, PH1L NI, Pheo, phil 9289, phillbriggs, phillyhall, PHILMEWAGON, PhilYerBoots, phil_monk31, Pigeon142, Pinocchio, PiperRS, pj1985, PlatinumCupra, plipman, PLuKE, PnP, pointypatrol, Poko, POLMAN, Poochy, POPOV, porksword28, powly1621, PPHenry, pr0xy, predo, prezf, probee, Proby, processpaul, Project1P, ProSpec, pstables, PSV6, Ptar64, ptycupra, Pure:Torque, push, putridmocha, pwskingle, qczarq, Quadrablast, QuietQuackers, quintonrose, R 20vt J, r1kbo, r30lac, r401caw, R4cup, racer66, Racheluk, Rael, RafLad, Rafterman79, ragazzi, rageuk, ragga63, Raider, Rallye Dale, ramborobert, Rampage, Rarpuc, rastajambo, Ray_n_Debs, RazorBoy, realneal00_0, Red ibiza, redcupra07, Redemption, RedFive, Redgie, redkite, RedR, redreligion, RedRob83, reece1591, reesy, Revo Kev, Revon, Rhys Beal, ri5t0, Rich12885, Richard D, RichardB, richardc, RichFR, richibiza, richicupra, RichN, Richoscos, richserena2310, Richy!!!, richybigman, Rich_Derv, RickyD1975, rickyleon, Rigla, riker, Rikman, rikwandi, rik_t, Rivva, rllmuk, Rob FR TDi, Rob GTI, Rob-Cupra, Rob66, rob929, Robbo73, robbob, robcorkhill, ROBD--M15RPD, robdf2, RobDon, Robert Barnes, RobFR, RobH, robin cur, robin_nerf, robjnr, robo2731, RobsCupra, robt880, robthebubble, Rob_B, rockape, rocket_26_, Rodie121, RodneyA, roiLaredo, Romigo, Ron Conno, Ronin225, Rorza, ross27, rosshutchie, Rosskie, rpmleon, rryans11, RSBUBBA, rsrich, rsulam, rsx, rs_jon, Rua1r1, rudgey, Ruff Ryder, Ruffy, RuidCi, Russ3474, Russ_tdi, Rusty Nuts, Rusty2k, rv2583, Ryanoceros, ryehorse, rödcupra, S2TTB, s3atl3onFR, s700 mcv, saintelise, Sam89, sambryant, Sammae, sando88, Sano, Sast, satli, sau, Scby555, scoota80, Scott.T, Scottmf, scotty026, scotty1310, ScrapMechanic, sd123sd, seagully, SeanCorky, Seanographer, SeanyK, Seat racer, SEATCOOBER, seatcupramad23, SeatDanny, seatkev, seatstu, seatturbopower, seatvirgin, seat_rich, Seb_P, secret.squirrel, Segger, seione, SexySeat, Sh0ckwave, Shadders, Shandy, Shapin, Shar, shaunymac, Shaun_E, shaw25, sheffboy, Shepdog, shnazzle, Shrek, Si, sibbocupra, Siboneh, sie77, SigmaDelta, Signor Whippy, silver surfer, silverfox, SimD1978, simon128927, simon54321, SimonFRTDI, simonp123, Sinbad, singh123, Si_TDi_FR, sk4tec, skard, skiddusmarkus, Skisbp, slappy_dunbar, slim20vt, slysi84, Small, smbitin, Smee, Smigger, SMiiTHY, Smiler-MK2, Smurfy, SNAP-ON, Snarks, snavE ttaM, Sneaky1337, Snower20vt, Snowsurfer, soche, sonic11, sotaville, Space Coyote, sparkie1984, Sparkopolo, Sparksy, sparky707, Spawney, spearce, Speedy83, SpidaCZ, spiralfries, Spirit Furtive, splinter26, splinter_cdo, splitpin, sportbilly, springer, spud31, SpursMadDave, Squealy, SRStdi, stabilo, Stakeknife, staneko, ste-lfc, SteA, Steed8, Steede, stefanbrash, Stegor, stellabelly, stephen1982, stephenSF, steve7786, SteveClarkFR, stevedevett, stevesulsh, SteveTDCi, steveyg, stevie go, StevieCupra92, Stevoz03, stevo_nwuk, stewbie55, Stewprovo, Stiggy, STOCKY, Stonesie, Storey1984, stpete, Street, streetbeef, string, stu666, Stuart19577, Stuart83, STUARTCLARK1982, stuflo, stuFR, Stupra, Stylance, StylancePaul, Subc, Suddy, Suicida1 Zombie, sunny2k2000, Super gaz, superkarl, Supershorty, superstu88, surajb1, surfo, swannley, T-Bull, T0DDY, t0m, t121anf, Taipan, Tam, TAOTAO, tapman, TarekElsakka, tatestar1, techieboi, tehguy, telmo.r, TFSI Elise, Tfsi_Mike, th0m4s- c33, Thafussa, thaivol, thanassis, The Old Codger, The poloman, TheCraig, TheDean, thefatplasterer, thermalp4, thestonegate, Thompa93, Thor_Asgard, Tiburon, TidzaCupra, tim1547, TimJK, TimJohnson, Timmyboy, TimSawf, TJenkos, toca72, toilet, toledoChris, Tom B, tom t, tom.b, Tombstoneuk, Tomer 20VT, tomhcupra, Tomibz, tommy918, tommy_a, Tom_SE_2009, Tonezz, tonipieleanu, tonto, tonycane, toot, Toxic, Traction, tractorboy, traumapat, Trekkie, trevorg1988, Tricky Red, triggster, trippy21, TrophyJem, truant2000, Trublu07, truss, TSI BOY, tundrarocks, turkish, Twisted1, Tylerjet, T_Free, uncle, Uncle Fester, unclelonghair, uniseat, unsheenashashin, unyonion, Updown789, uzzy, v0id, vagmanFR72, VAGUE, ValeriCUPR, valverjam, varley16, vdawg, veloc123, Veyron, vfr400racer, vialli69, Viking, Vimes, vINyL3, Virdz, viren, volvic, vRSy, vtxracer, w.reid306, w5ccb, waggyy, walkerfr, Wallie, Wama, warren30, warren_cox, wazza16, webb204, webdiod, webhype, webwysard, Weedall, WeeG, weejim, Weetz, Wellsy, WelshConan, Welsh_Steve, Weslington, westy2k1, wezy0, whitecuprak1, WHOZBOSS, wigz45, wild willy, WileEcoyote, Wilko, wilksy, wilky19, will-fairburn, willber, willc, williburp, Willz17, Wilson9, Wimbledonian, window60, windy1664, Wings988, Wire_Gal, wisejason, wolfiecuprar, womble68, worleyg, Worthy93, WRC555, Wullyboy, WW_VRS, X cupra, xander_leon, xavier de, xhellixx, xreyuk, xyz, Yannerson, yarlie7, yaue10, yaza01, yazmidani, yea_good_1, Yello, yellonvi-R, YIN, YoDan, Yohan87, yooni7, Youbee, younger25, Youngy81, zak, ZiggyEP3, Zipcode, [M]ike, _chris_, _sql_
Thread Tools
Display Modes Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
ibiza 2008? Offspringy Ibiza Mk5 182 30-05-2008 22:05
Revo map for NEW Mk2 Leon Cupra warren_cox Leon Mk2 83 19-10-2007 09:17
Website © 2014 SEATCupra.net
Disclaimer: SEATCupra.net is not an official SEAT site and is not affiliated to SEAT in any way. Visit the Official SEAT Website.
SEATCupra.net are not directly responsible for information which maybe posted in this forum.
All content is viewed and used at your own risk. We do not warrant the accuracy or reliability of any of the information.
The views expressed herein are those of the individual contributors and not necessarily those of SEATCupra.net or SEAT
All trademarks and copyrights remain property of their respective owners.
